04-22-2018
13:43
20:08
04-22-2018
13:43
20:08
Is there any way to see the Alta HR display when you are outside? Device is useless outside even as a watch.
06-02-2020 06:34
06-02-2020 06:34
06-13-2020 12:52
06-13-2020 12:52
Is your Alta a newer version? Mine is about 4 years old and I have the viewing problem that was discussed.
06-14-2020 17:21
06-14-2020 17:21
06-15-2020 17:12
06-15-2020 17:12
06-15-2020 17:25
06-15-2020 17:25
06-15-2020 17:34
06-15-2020 17:34
Mine is about 3 years old. It’s always had the issue where it was hard to read outside if it was sunny. This was annoying, but pretty typical of a digital display. Recently, the display has gradually gotten less bright so that it is now hard to read indoors, even with low lighting. I’m curious if this is a known issue as they get older, or just some freak defect with mine
06-15-2020
18:00
09:25
AlvaroFitbit
06-15-2020
18:00
09:25
AlvaroFitbit
I still can see mine fine indoors. The face has a crack so I’d like to get a new one but hesitate if the new Alta has the same problem. I love the size and the simplicity of the tracker.
Moderator Edit: Personal info removed
06-16-2020 05:17
06-16-2020 05:17
06-16-2020 07:05
06-16-2020 07:05
06-17-2020 14:42
06-17-2020 14:42
Found the same thing - display got so dim, can't read it even inside but it's 2 years old now so no chance of warranty
