03-28-2016
17:30
18:43
03-28-2016
17:30
18:43
Is there a trick to getting the alta to even turn on?? Been charging for 5 hrs. Restarted, turned blue tooth on and off tried to call customer service.. Couldn't get through. This is my first one and I'm not impressed if it's this hard to set up
Moderator Edit: Updated title for clarity.
02-18-2018 13:09
02-18-2018 13:09
Best Answer03-02-2018 15:59
03-02-2018 15:59
I had the same problem, couldn't get past the setup wording on the Fitbit but no code would come up. I turned my phone off and on with blue tooth on and the number automatically popped up. I was still connected to my computer and charging.
Best Answer05-07-2018 16:48
05-07-2018 16:48
I am having the same problem. I can't get it to connect to the bluetooth. It's fully charged.
Best Answer05-07-2018 17:02
05-07-2018 17:02
Best Answer11-27-2018 21:56
11-27-2018 21:56
Works as advertised when connected to the charger. And linked via Bluetooth to my MacBook. I take it off the Charger and my Alta disconnects from Bluetooth and the screen stays blank
Best Answer11-27-2018 21:57
11-27-2018 21:57
Alta works as advertised when connected to the charger. Showa being linked via Bluetooth to my MacBook. I take it off the Charger and my Alta disconnects from Bluetooth and the screen stays blank
Best Answer02-06-2019 09:19
02-06-2019 09:19
I have same exact problem can’t turn it on n can’t get it synced I’ve tried everything Soo frustrated!!
Best Answer01-15-2020 21:00
01-15-2020 21:00
same issue. unbox it and charge, but failed...............no one can help
