01-11-2024 06:49
01-11-2024 06:49
The plastic wire covering split on my charger so I need a replacement in the U K. Sent to eBay and Amazon and neither worked. They only had two prongs and not three.
01-16-2024 12:38
01-16-2024 12:38
@Shirlchristine the Alta HR was discontinued in 2019. There is no later model for that device. Can you share a photo of your charger with 3 prongs? That is not something I've ever seen and now I'm curious.
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
01-13-2024 10:11
01-13-2024 10:11
@Shirlchristine the charger for the Alta HR has two prongs, not three. It looks like this.
01-15-2024 06:07
01-15-2024 06:07
My previous charger had three prongs to align with the three dots on the Fitbit. Is your version a
later model?
01-16-2024 12:38
01-16-2024 12:38
01-16-2024 12:42
01-16-2024 12:42
01-16-2024 12:50
01-16-2024 12:50
@Shirlchristine can you buy a 2-prong charger from Amazon and try it out? I think it will work for you but, if it doesn't, just send it back.
On the other hand... the Alta HR is an older device. It was replaced by the Inspire line. The current version is the Inspire 3. It has a color display (which you can actually read outdoors), a better quality band, and a bunch of new health metrics.
