Charger replacement needed for Alta HR in UK
ANSWERED
The plastic wire covering split on my charger so I need a replacement in the U K. Sent to eBay and Amazon and neither worked. They only had two prongs and not three.
1 BEST ANSWER
Accepted Solutions
@Shirlchristine the Alta HR was discontinued in 2019. There is no later model for that device. Can you share a photo of your charger with 3 prongs? That is not something I've ever seen and now I'm curious.
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
5 REPLIES 5
@Shirlchristine the charger for the Alta HR has two prongs, not three. It looks like this.
My previous charger had three prongs to align with the three dots on the Fitbit. Is your version a
later model?
Sorry, I threw it away as being unsafe. Looks like I need a new watch.
@Shirlchristine can you buy a 2-prong charger from Amazon and try it out? I think it will work for you but, if it doesn't, just send it back.
On the other hand... the Alta HR is an older device. It was replaced by the Inspire line. The current version is the Inspire 3. It has a color display (which you can actually read outdoors), a better quality band, and a bunch of new health metrics.
