03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
12-05-2016 20:28
12-05-2016 20:28
Mine also does not clasp easily the pushing is not enough.
12-06-2016 04:15
12-06-2016 04:15
11:39
15:18
ErickFitbit
12-06-2016
11:39
15:18
ErickFitbit
My son just got me an Alta as a gift. I've tried several of the solutions that were mentioned and am still having great difficulty clasping it onto my wrist (that is when I can actually get it to clasp). After seeing all of the posts about the difficulty in clasping the Alta onto your wrist, it is incredulous to me that Fitbit hasn't redesigned it so that it is actually usable. Plus, it should work as expected out of the box - one should not have to Google solutions that work for some and not for others. very disappointed in the flawed design!
My two cents.
Moderator edit: format
12-06-2016 13:49
12-06-2016 13:49
totally agree. very disappointing considering the price. I still struggle with mine, end up pulling hairs on my arm, digging into my skin, oil all over the place (as per a suggested solution) . come on fit it get professional, not Mackey mouse?
12-06-2016 16:49
12-06-2016 16:49
12-07-2016 13:03
12-07-2016 13:03
@BobShelby @Deniselt Sorry to hear about the difficulty that you've experienced with clasping the Alta. I appreciate the feedback and will make sure to pass it along to our design team. If you're still experiencing issues with clasping the Alta I recommend checking out our Tory Burch, Public School, or Simply Vera accessories as alternatives.
12-07-2016
16:39
07:38
AnnieFitbit
12-07-2016
16:39
07:38
AnnieFitbit
My point exactly...why doesn't Fitbit change this horrible clasp that everyone struggles with?
Judy
Sent from my iPad
Moderator edit: Format.
12-07-2016 18:59
12-07-2016 18:59
@ErickFitbit are the alternatives that you mentioned complimentary alternatives, or do I need to purchase them? If I need to purchase them to replace a design flawed clasp, then Fitbit really does not understand or care about their customers. Fitbit should resolve the problem with the current clasp rather than suggesting that their customers buy a new one for a brand new Fitbit.
12-08-2016 18:06
12-08-2016 18:06
Li5aMarie... I am having the same issue. My Alta has fallen off several times today. There's no way I can wear it now. So frustrated rifht now!!!
12-09-2016 09:34
12-09-2016 09:34
Best Answer12-11-2016 10:00
12-11-2016 10:00
Hello there @Savysam, @BobShelby, @JudyNP! Glad to see you around in the Community. And welcome @BashamB! Hope you have a great time. ![]()
Thank you very much for all your feedback. This is super important for us, so I'll make sure to pass ir along. Also, thanks to @Savysam for the great tip!
@BobShelby, the accessories mentioned in Erick's post are purchased separately. The Alta tracker includes an elastometer band only, so the leather bands, metal bracelets and the Designer Collection bands are sold separately.
@BashamB in your case, my best recommendation is to contact our Customer Support team and explain the situation to them. I'm sure they will be able to assist you further with this one.
I'll be around! Let me know if you have any further questions. ![]()
Was my answer helpful? Awesome! Let's help our fellow Fitbitters by marking this as a solution, and vote up! 😄
12-11-2016 11:28
12-11-2016 11:28
Not impossible to put the Alta on, but still ridiculously hard. I struggle putting it on my wife's wrist.
I liked the suggestion of using the clasp release points where it meets the bit itself and will try that. If that doesn't work, I'm not going to indulge (the very valid) workarounds, I'll just return the Alta.
12-11-2016 20:54
12-11-2016 20:54
12-11-2016
23:29
05:18
AnnieFitbit
12-11-2016
23:29
05:18
AnnieFitbit
The following iw what I wrote to fitbit in response to their request for feedback on this issue.
It appears many people do not like the current wrist strap on the alta model. it is all very well giving "tricks" to overcome the problem but this is fitbits problem and they should find a permanent and "Professional solution". Meanwhile I think purchasers would be warned of the problem before they purchase. This is not the way you would expect an honest and reputable company too handle the problem.
Fitbit you have a realy good product why spoil it with a silly thing like a faulty strap?
12-12-2016 04:43
12-12-2016 04:43
@SunsetRunner Thanks for joining us in this thread and welcome to our Fitbit Community! I really appreciate your feedback regarding the Alta's wristband. This helps us to keep improving our products and services.
Let me know how if more help is needed my friend! ![]()
Best Answer12-12-2016 05:58
12-12-2016 05:58
Best Answer12-12-2016 15:39
12-12-2016 15:39
Hi Juan,
Thank you for the suggestion. I am trying your suggestions. It hurts a lot still to put on. I like how fitbit charge HR 2 is designed.
Best Answer12-13-2016 03:43
12-13-2016 03:43
@Shilpa71 Thanks for getting back! I appreciate your interest in our Fitbit Charge 2. If you are still having issues with your Fitbit Alta, and you bought it from our Fitbit store, I recommend contacting our Customer Support team so they can review your case and start a return process in case your tracker is still within the return window, if you want a refund in order to get the Charge 2 instead.
Keep me posted if more help is needed my friend! ![]()
12-13-2016 07:37
12-13-2016 07:37
UPDATE: I did a 'Live Chat' this morning with Fitbit and explained my issue. Because I was within the one year warranty, they had no problem ordering me another one at no cost to me. And the agent was so extremely helpful and personable. Made a frustrating situation so much easier. 🙂
12-13-2016 07:55
12-13-2016 07:55
