03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
05-21-2017 11:11
05-21-2017 11:11
Best Answer05-22-2017 17:21
05-22-2017 17:40
05-22-2017 17:40
Sadly, I won't be part of this community anymore. As of early last week, my Fitbit came off of my wrist and I have been unable to locate it. It had come off several times in the past if I brushed up against something and I was always able to find it. Was just a matter of time before it came off and was lost due to the faulty band. The only silver lining in that cloud is that Fitbit FINALLY changed the band so that it is more traditional and secure.
Sorry to see my Fitbit go, especially since it was a gift from my son.
Best Answer05-22-2017 18:35
05-22-2017 18:35
05-29-2017 18:16
05-29-2017 18:16
This is the worst design ever for a wristband. I wonder how many tests were performed before this went to market.
05-30-2017 08:56
05-30-2017 08:56
I could not agree more. The company should revise the band and offer it to any one who bought this model. Shame on them
06-18-2017 08:25
06-18-2017 08:25
I wholeheartedly agree that buying and trying to use the bit is an exercise in nothing but frustration.
I think there ahould be a recall and all bracelets replaced replaced with something that works.
06-18-2017 10:27
06-18-2017 10:27
Some of us have had no problems.
Best Answer06-19-2017 15:36
06-19-2017 15:36
The snap band was so much trouble and frustrating to put on each day it was ridiculous. I even tried switching wrists and now both thumbs are sore from trying to clasp it. I went to Amazon and bought a better band, switched bands and it fits so nice. Too bad I couldn't use the band that came with it.
Best Answer06-20-2017 13:29
06-20-2017 13:29
Just to let you all know, the "alta" has a new buckle band, as well as the regular snap band. So, now there is a choice.
Hope this helps
Myra
07-03-2017 07:38
07-03-2017 07:38
Honestly this is a crappy design. I hope the fitbit folks are looking at how many people have issues getting this band snapped. I have to struggle and struggle and it's almost to the point that I'm going to return it and order something different, which is a shame, because I love the Fitbit Alta itself.
Why not just have a buckle design option?
I'm 65 and this is REALLY more difficult than it should be!
Best Answer07-03-2017 07:59
07-03-2017 07:59
They now have a buckle design too.
07-03-2017 08:08
07-03-2017 08:08
They do?
I wonder why it wasn't offered.
I'll go look in the store. Thanks.
Best Answer07-03-2017 10:09
07-03-2017 10:09
Best Answer07-12-2017 22:32
07-12-2017 22:32
I have had my Altra for 6 months and in the last 2 months I have lost it 4 times (thankfully returned each time...just pure luck). I am diligent in ensuring the clasped are connected but now I am afraid to wear it! This fitbit is useless, unless I can find a solution??????
Best Answer07-12-2017 22:38
07-12-2017 22:38
I have had my Altra for 6 months and have lost it four times (returned each time due only to good luck). After I lost it the first time and made sure I knew how to connect the band and are diligent each time...to no prevail. I now to not wear it so it's useless unless I can find another solution????
Best Answer07-13-2017 05:03
07-13-2017 05:07
07-13-2017 05:07
When I first ordered my alta, I had read about some little silicon bands available through Amazon so I ordered them just in case I needed them and they help.
Best Answer07-13-2017 06:21
07-13-2017 06:21
Best Answer07-13-2017 10:57
07-13-2017 10:57
