03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
05-27-2018 17:54
05-27-2018 17:54
I agree - I just bought my Alta, and have spent quite a bit of time trying to get it to stay on. This is an extremely annoying feature. Fitbit people, try to come up with a different design for these bands. They need to work better.
Best Answer05-30-2018 16:28
05-30-2018 16:28
My wife just received this Alta Fitbit and it is a throw away. It takes a pair of pliers to fasten the band. What a waste.
Best Answer05-30-2018 19:33
05-30-2018 19:33
Lindaroo & Bob.terry: This is what I do. I clasp the bands together just where I want (before it is on my wrist) Then I attach the band to the fitbit. After I attach the band to one side, I then attach the other band (side) to the fitbit. Now, it's on your wrist & you are ready to go. Were you able to understand what I posted (this takes less than a minute to do once you clasp the bands together) If you are confused, just give a hollar.
Happy Stepping, Myra
Best Answer05-30-2018 19:39
05-30-2018 19:39
05-30-2018 21:23
05-30-2018 21:23
I was annoyed, too, and still feel Fitbit folks should include more info about the band ; but bob.terry, please read others' comments for dealing with this.
- Before putting it on, release the band on one side close to the unit (pinch the metal latch and pull up.) Now it's in 2 pieces, 1/2 the band and the unit attached to the other 1/2 of the band. Then snap the button pins into the holes while it's not on the wrist. Then put the band, open at the top near the unit, on the wrist and snap the metal latch back in place.
After a few weeks of this, the holes will have stretched a bit so the band can be closed at the pins more easily and the Fitbit can be put on in the normal way.
Best Answer05-31-2018 20:37
05-31-2018 20:37
Nan, I just saw this post now. I have arthritis & the buckle bands were also hard for me. So I do the buckle bands the same way as the bands with the holes & it works. In fact, I have a buckle one on now. Are you having any problem with the bands from Amazon? A few months ago my sister ordered the bands from Amazon for $10. The bands kept falling off her wrist. She was lucky & didn't lose her Fitbit. But, I just noticed you have the buckle bands from Amazon (maybe the buckles are better. Hers were the original.
Myra
Best Answer12-20-2018 13:51
12-20-2018 13:51
I've tried the tips you posted to try to get my Charge HR on. I put it away in a drawer over a year ago because I have never been able to get it closed - even when it's off my wrist! Any other suggestions?
Best Answer12-20-2018 17:52
12-20-2018 17:52
Best Answer12-20-2018 18:31
12-20-2018 18:31
Best Answer12-20-2018 20:39
12-20-2018 20:39
Hi Beadsis: Yes the Charge HR is different from the Alta. However, if you just got your fitbit, maybe because it's new, you just need to loosen it up a bit. Try a few times before putting it on your wrist. Hope this helps.
Myra
Best Answer12-20-2018 21:52
12-20-2018 21:52
I can't even close it when it's off my wrist!
Best Answer12-21-2018 00:30
12-21-2018 00:30
I just bought a replacement watch strap (that fits a Fitbit) from Amazon for a few pounds, the conventional adjustable type. It’s well worth it.
Best Answer12-21-2018 11:04
12-21-2018 11:04
15:44
04:39
FerdinandFitbit
12-21-2018
15:44
04:39
FerdinandFitbit
You are very welcome. I’m so glad it helped
Cing: So glad you were able to get another band that fits & easier to put on your wrist.
Moderator edit: Merged replies
Best Answer12-30-2018 05:50
12-30-2018 05:50
I agree , I made the mistake of undoing to put on my wrist - HA HA HA ("cos thats the idea isn't it - wearing it), But can i actually put it on No. This is the third on i have had, when they work they're brilliant - I have never had this problem before.
I will try the suggestion of rubbing olive oil in the holes, with my shky hands this will be fun, however i can see myself buying a new strap. Im eager to get it on record my steps and efforts to lose weight.
*But the question is the FITBIT - why does it have to be so difficult, i have cerebral palsy - i don't have strength in my hands ,i have been pushing for just 5 mins ,my hands are hurting and shaking, where as i knw i can ask my husband. Hopefully you will understand i want to do it myself!!
Best Answer12-30-2018 08:39
12-30-2018 08:39
Best Answer12-30-2018 08:56
12-30-2018 08:56
12-30-2018
08:57
04:43
FerdinandFitbit
12-30-2018
08:57
04:43
FerdinandFitbit
Good idea, now just got to get done up, so that it will stay on
Thankyou For whoever suggested sticking a knife blade in, I don't know what it took of but im now wearing it, s for spraying with olive oil Did'nt have to try that. I did try and take the end of and couldn't do that
Best Answer12-30-2018 10:54
12-30-2018 10:54
Best Answer12-31-2018 05:45
12-31-2018 05:45
Someone on here suggested , olive oil or a blade in the whole. I figured out the number i would permanently use the strap on. So got the tip of the blade in whose holes. It worked.
I would give it a try while you're awaiting your sstrap
