01-04-2017
23:08
18:17
01-04-2017
23:08
18:17
My band smells terrible. I wear it all day so it may have picked up smells from me cooking. It smells like cat pee to me but maybe it's from chopping onions. I've tried cleaning it with alcohol and toothbrush. Didn't work at all. Any help?
01-05-2017 04:52
01-05-2017 04:52
Support suggested I use a little rubbing alcohol.
Also to clean the alta itself, http://help.fitbit.com/articles/en_US/Help_article/2005/?q=wear+and+care&l=en_US&fs=Search&pn=1
06-29-2017 19:08
06-29-2017 19:08
Rubbing alcohol and a toothbrush didn't help the smell at all. Mine smells like cat urine as well. It's embarrassing enough that I will stop wearing it. My flex lasted less than a year and died and now my Alta is getting retired at under a year old due to the smell. I have taken the band off and clasps out to clean it but it still smells. These products are supposed to be durable enough to tolerate hot sweaty work outs but obviously they do not.
07-01-2017 09:37
07-01-2017 09:37
Thanks for visiting the Forms @M_Y @Hodges5496 @rdytolose
In addition to great tips provided above I recommend following the "Wear & Care" tips and keep an eye on it, this would definitely help.
Let me know how it goes!
07-02-2017 07:07
07-02-2017 07:07
05-13-2018 10:36
05-13-2018 10:36
Mine does too! HELP! I really love this product except for the smell. Did they use recycled plastic to make them I wonder?
06-26-2018 14:25
06-26-2018 14:25
I've noticed latley my fitbit also smells like cat pee I tried cleaning it and it still stinks glad I'm not the only one
08-21-2018 14:10
08-21-2018 14:10
My Fitbit Alta HR also smelled like cat urine. I saw this post and tried cleaning the band while it was attached to the Fitbit. This did not work. Then I found the owner’s manual online and found how to simply remove the band from the device by pushing on the two metal tabs. It slid right off and I found the source of the smell. I was then able to give it a thorough cleaning and it smells much better!
Thanks friends for for your help!
01-20-2019 19:53
01-20-2019 19:53
I discovered that the odor comes from the Fitbit, not from the band. Lengthy thread on the Surge forum confirmed that my nose is correct. Can no longer sleep with it because of the smell. I wonder if people around me at work can smell it. Really disappointing because swapping out the band won't do jack.
05-11-2020 21:17
05-11-2020 21:17
Omg. I thought I was going crazy. Like, was the cat peeing on my wrist while I slept??? So glad it’s not just me. I have tried burying the thing in baking soda, it helped for a couple days then the smell came back. I’ll try rubbing alcohol and toothbrush. Would really like to find a solution as I am addicted to my Fitbit but canNOT deal with cat pee smell in my wrist.
05-12-2020 07:08
05-12-2020 07:08
05-31-2020 15:57
05-31-2020 15:57
I keep getting a smell of cat pee from my strap - I have had to take off ! Any suggestions on how to get rid of the smell. I wash this regularly but does not get rid of smell
07-04-2020 01:30
07-04-2020 01:30
It took me a minute to figure out the cat pee smell was my Fitbit. I don't even have a cat so I couldn't figure out where it was coming from. I tried cleaning it too and no luck. I guess I won't wear it anymore. Like another commenter said, I really hope other's couldn't smell it. So embarrassing.
07-04-2020 02:16
07-04-2020 02:16
09-12-2020 13:34
09-12-2020 13:34
Regarding fitbit band smelling like cat urine:
I have had this with some of my athletic shoes and found out it is because the rubber used, when exposed to moisture, emits an ammonia smell. These watch bands are made with some kind of synthetic that when exposed to moisture will emit something that smells like cat urine. Very nice. Thank you Fitbit. I will not buy another of your products because of it.
09-12-2020 13:40
09-12-2020 13:40
It is from the rubber. Check out athletic shoes and cat urine smell. It happens with the sythentic rubbers they use in shoes as well when exposed to moisture/water.
09-12-2020 13:41
09-12-2020 13:41
I know why but can't tell you how.
