07-28-2017
07:51
18:17
07-28-2017
07:51
18:17
I never received my 40,000 step badge and I don't know how to get it to show up. I did get the 35,000 badge for that day, but not the 40,000 badge.
I didn't manually enter anything either.
07-28-2017 19:20 - edited 07-29-2017 16:33
I know this is from a bit a go, but I got my 35,000 badge for that day, but not the 40,000 badge. It was over 40,000. All recorded by the Fitbit and not from another app or manual entry.
I talked to someone at FITBIT and they fixed it for me. Thanks!
Best Answer07-28-2017 19:08 - edited 07-28-2017 19:09
Thanks for stopping by @ParkMom! Please double check that you are not using a third party app to log activities. Only steps recorded by your tracker, SmartTrack, MobileRun or MobileTrack are counted toward challenges.
To better assist you, please attach an screenshot of the date you have achieve the 40,000 or more steps.
Keep me posted! 🙂
Best Answer07-28-2017 19:20 - edited 07-29-2017 16:33
Best Answer09-12-2017 00:38
09-12-2017 00:38
Same thing has happened to me, I received the 35,000 step badge but not the 40,000 step badge. Step count for the day shows 41,413. Could you help please.
Best Answer05-01-2020 03:24
05-01-2020 03:24
It seems Fitbit does not give you a badge for the highest badge you've earned. It only gives you a badge for the next badge earned. For example, if you've earned the 35,000 step badge and then walk 50,000 steps you should get the badge for 50,000 steps. Fitbit will only give you the badge for the next highest level which would be 40,000 steps in this example.
