02-03-2016
10:12
18:43
02-03-2016
10:12
18:43
Does the Alta track levels?
Moderator edit: edited title for clarity
05-06-2017 19:23
05-06-2017 19:23
Ahhhhh that makes sense!
Best Answer05-06-2017 20:28
05-06-2017 20:28
05-06-2017 20:30
05-06-2017 20:30
I've heard the heartbeat doesn't even work on any Fitbit.
Best Answer05-06-2017 20:38
05-06-2017 20:38
05-06-2017 20:43
05-06-2017 20:43
I am sorry. I get discouraged easily. People have told me steps aren't even accurate. I don't know. I do love my Alta though 😊
Best Answer05-06-2017 20:49
05-06-2017 20:49
23:45
14:11
LenaFit
05-06-2017
23:45
14:11
LenaFit
As per the product page, it is waterproof to an extent. Just don't wear it
in the pool (and definitely not in the ocean).
"Water Resistance
Alta is rain, sweat and shower proof, but not swim proof. Rinse and dry
Alta after showering because it’s best for your skin if the band stays dry
and clean."
As for tracking exercise, it can only track motion it can detect. It would
never work on a stair master because your arms don't move when holding the
rails. Placing it on you sites or ankle fixes this since your feet are
doing all the moving.
This is why the elliptical machine is specifically mentioned as a supported
exercise, since your arms move very clearly. I would image a rowing machine
and similar exercises would get tracked as well, but since they're not
specifically supported they wouldn't get recognized for exactly what they
are.
Eric
Moderator edit: Removed personal information
Best Answer08-31-2017 17:17
08-31-2017 17:17
Since the Alta does not track floors, how about a manual method to enter floors. My iPhone tracks floors for me. If the fitbit app interfaced with that data, like some other apps, it could automatically update, but I'd settle for manual entry.
Best Answer12-31-2017 12:38
12-31-2017 12:38
It is waterproof
Best Answer01-05-2018 05:30
01-05-2018 05:30
It does register your heart rate
Best Answer02-08-2018 06:31
02-08-2018 06:31
I find the reasoning questionable considering that it's not any smaller than the fitbit one which does have an altimeter.
12-16-2018 06:32
12-16-2018 06:32
I agree. It’s my fault. I just assumed it would count floors. I was looking to change from my Fitbit One to something I could wear on my wrist. I used to hook the One to my bra strap. This is a real disappointment..
12-16-2018 06:34
12-16-2018 06:34
From what I gather, there's no display function to track floors, but it tracks the steps only.
Best Answer02-01-2020 05:25
02-01-2020 05:25
How do you get the floors on your Fitbit
