03-15-2016
18:57
18:43
03-15-2016
18:57
18:43
my fitbit was in the middle of updating with the app and then it just stopped and now has an exclamation point and wont do anything and my app now says it cant connect?!?! i have tried the restart thing where you plug it in and push the botton on end of charger 3 times and does nothing
Moderator Edit: Updated title for clarity.
03-06-2017 14:01
03-06-2017 14:01
What is the solution?
03-06-2017 17:05
03-06-2017 17:05
@ADOC I recommend restarting the Alta and then giving the firmware update another try. Let me know if that helps get you back on track.
05-20-2017 16:19
05-20-2017 16:19
I have done what the instructions said to restart my tracker and still get the ! mark. Any other help?
I just got mine 2 days ago and it's charged up to medium.
08-06-2017 11:46
08-06-2017 11:46
I've done everything listed and my Alta still won't work. It was fully charged yesterday but I believe the message I get is that my battery is empty. To note, I've had issues with this battery in the past, even with turning off Bluetooth. Any other suggestions would be greatly appreciated.
10-31-2017 20:19
10-31-2017 20:19
Yup I deleted the app from my iPhone and redownloaded it and it finished the update and now works again. But remember to remember your password for your Fitbit account before you delete it.
11-30-2017 14:41
11-30-2017 14:41
Same thing happened to me No idea what to do it has been like this for almost a week now and have tried everything. I only got it at the start of October and less that two months on it has stopped working all of my family members also have Fitbits that have never done this please help
12-28-2017 16:52
12-28-2017 16:52
Ugh same
01-02-2018 08:17
01-02-2018 08:17
Hi ErickFitbit,
Thanks for trying to help out, but your post is only frustrating users. If you read the original posts, you'll see that the RESET does NOT help. In my own experience, the Alta does not reset when showing the !. p.s. I've tried the 3 clicks and also the 2 seconds & remove techniques. The Alta only turns on/off the !
Like other users, I was in the middle of an update that got interrupted. Is my only recourse to return the Alta?
Note: this is all about the PC. I will try to get the Alto to connect/run using the original phone too.
BUT PLEASE, DO NOT TELL USERS TO ATTEMPT RESET WHEN THE ! IS SHOWING AFTER AN INTERRUPTED UPDATE. You're giving bad info (or else I have a bad original new dongle).
01-02-2018 08:19
01-02-2018 08:19
p.s. See Kreed82 post on 03-17-2016 20:23
Same thing -- the ! does not allow/enable the reset.
03-05-2018 18:04
03-05-2018 18:04
I have no other device to synch it with. What do I do to get rid of the exclamation point? It's just stuck.
03-17-2018 06:30
03-17-2018 06:30
I keep getting n exclamation on the fitbit screen and it will not connect to my phone
05-08-2018 12:44
05-08-2018 12:44
This did work but i had to reset at least 4 times before it worked Thanks!!!
09-17-2018 08:27
09-17-2018 08:27
I am unable to update my Fitbit. I have an IPhone 7, tried turning off my phone, and it keeps telling me firmware system is busy
01-09-2020 13:23
01-09-2020 13:23
I searched half the internet for a solution with the exclamation mark.🙈
My solution: Try a different phonedevice to do the firmware update.
I tested some older phones: Samsung, Cubot, Geotel: everytime the update brokens at ~2% and after this: Exclamation mark!
Then I told my daughter 😁 she came along with a newer Samsung phone. App installed, Fitbit connected (this works with exclamation mark too, because there runs some kind of mini-OS), and started the whole configuration again and updated again, then it WORKED, the update takes some minutes and after this everything runs at a charme.😳
Background: I think, older smartphones have older Bluetooth equipment built in. This the fitbit (or a Samsung Galaxy Fit with exclamation mark too) dont like 🙂
But you never get an error-message 😝
May be the developers like to test only with new hardware around them. Older Smartpones are not hip enough 😉
02-06-2020 19:07
02-06-2020 19:07
check this out https://www.youtube.com/watch?v=g223JepUZT0 it may help you all 😊
07-06-2020 21:02
07-06-2020 21:02
I know this post is old but I just had this same problem so I thought I would post how I solved it in case other people are still having this problem. I tried everything that other people posted: pressing the button three times, restarting my phone, deleting and re-downloading the Fitbit app, turning off Bluetooth and turning it back on but the solution that finally worked was I opened the Bluetooth page on my phone, I clicked on the Alta HR (which said connected), I clicked on “forget this device” and then I opened the Fitbit app and it finally started to sync properly. Hope this helps!
09-16-2020 15:26
09-16-2020 15:26
hi if you have been helped can you give me the tip for it i have tried everything i have reset app
12-23-2020 10:20
12-23-2020 10:20
The actual answer is this after 4 hours of my life doing all of these other suggestions:
-Download the fitbit app on your computer form the microsoft store.
-Uninstall fitbit app from your phone.
-Sign in to your fitbit account in the app on your computer (the app from the microsoft store)
-Connect your alta hr bluetooth to your computer. (your phone is still off)
-Then finally it will let you update the firmware to your fitbit alta hr.
-Then you can turn on your phone, install the fitbit app, and it will need to sync a few times, but it will finally take and work, as it needs a bit of time to tell your online account that everything is updated.
