03-18-2016
10:17
18:43
03-18-2016
10:17
18:43
How can I factory reset my alta?
05-13-2019 09:14
05-13-2019 09:14
I guess there’s something wrong with your battery
05-20-2019
15:26
04:53
05-20-2019
15:26
04:53
Hi @SunsetRunner. Welcome on board. @ccjackycc, it's nice to see you around and thanks for stopping by. I'm sorry for the delayed response.
@SunsetRunner, thanks for letting me know about your Alta, as well for the troubleshooting steps that you've tried. I've been informed that you already have a case created with the Support team and they're providing you assistance with this. I'd recommend to continue working with them so they can help you.
I'll be around if you need anything else.
07-05-2019 05:17
07-05-2019 05:17
The instructions on resetting the fitbit alta did not work for us. The fitbit will charge but the charge does not last a day.
07-07-2019
14:48
04:52
07-07-2019
14:48
04:52
Hi @TopekaJDA, welcome to the Community!
Thanks for letting me know about your Alta, as well for your efforts while trying the restart. Since the battery isn't lasting, please verify that you're charging it by plugging the charging cable into a USB port on your computer or using a UL-certified USB wall charger. The battery level will also depend on how frequent you're using its features. For that reason, please check this help article that includes tips to improve its battery life.
Give it a try and keep me posted.
07-07-2019 16:09
07-07-2019 16:09
07-07-2019 17:10
07-07-2019 17:10
07-10-2019 11:18
07-10-2019 11:18
I got my Alta HR from a friend. She already removed it from her account and all that. I have it paired with my phone and on my account but for some reason whenever we're together, my alta HR picks up her texts and calls. Is there any way to unpair my alta hr from her so I dont get her notifications?
07-10-2019
13:29
04:52
07-10-2019
13:29
04:52
Hi, @annnacarmina , yes! In addition to removing it from her Fitbit account, she will need to remove it from her Bluetooth connections to her phone. She simply needs to go to her phne’s settings, chose bluetooth settings / devices and remove/ delete the Alta.
Hpefully it will be clear hw to do this, but if yu need more help please just post again letting us know what phone she uses and someone will have more detailed instructions.
Enjoy your Alta HR!
07-26-2019
12:12
04:52
07-26-2019
12:12
04:52
Hi @SunsetRunner and @TopekaJDA, I'm glad to see you again. @annnacarmina, welcome to the Forums. @Julia_G, thanks for stopping by, as well for your great help! I'm sorry for my delayed response.
@SunsetRunner, thanks for keeping me updated, and I'm glad that your new Alta is working correctly. I'm sure you'll crush your steps!
@TopekaJDA, I appreciate your efforts with the steps posted above, and I'm sorry that the issue keeps persisting. I've gone ahead and requested a case on your behalf so our Support Team can give you a hand. You'll receive more details via email, so keep an eye on your inbox.
@annnacarmina, thanks for joining to this conversation, and it's great that you got an Alta HR from your friend. About the notifications, I'd recommend the steps suggested by @Julia_G. If her notifications are still going through your device, feel free to reply back.
Hope to see you around!
09-10-2019 19:16
09-10-2019 19:16
My Alta is stuck in the ! after an update that never ended. Tried the restart but still not working. I’m losing faith. What do you recommend?
09-22-2019 09:32
09-22-2019 09:32
The link listed Sunset Runner doesn't work. Can someone fix it as I cannot reset my Alta
09-22-2019 09:42
09-27-2019
12:06
08:46
09-27-2019
12:06
08:46
Hi @Gustavow and @elvis66. Welcome to the Forums. @Julia_G, thanks for your great help. I'm sorry for my delayed response.
Thanks for trying the steps posted in this thread, as well for letting me know about your Alta's behavior. I've checked with our Support Team and apparently they already took your case under their wings. Please keep an eye on your email inbox, you'll get some information about your case.
Feel free to reply back if you have another question.
11-27-2019 17:48
11-27-2019 17:48
KellyKenney,
I tried what you said on my gfs Fitbit Alta n it doesn’t work
12-10-2019 15:29
12-10-2019 15:29
This link no longer works - where are the instructions for how to reset an Alta? Can't find them anywhere...
01-07-2020 16:18
01-07-2020 16:18
my Fitbit Alta kemp’s dying while it is on my arm, then when I plug it in to charge, it says it has at least 70-80% left. Or if I take it off to bathe or shower, when I go to put it back on, it will be dead. Then I plug it in and the same thing happens.
03-02-2020 13:04
03-02-2020 13:04
I’m having the same problem. Worked fine for last 18months but last weeks his started to happen.
03-02-2020 19:21
03-02-2020 19:21
My new Alta won't reset. Followed instructions, but don't get the logo, just battery icon. It has stopped tracking sleep, other stats working fine. Suggestions?
03-02-2020 19:22
03-02-2020 19:22
Same here, no logo
04-15-2020 21:15
04-15-2020 21:15
Ok so I took the advise about restarting my Fitbit Alta hr and my Fitbit is responding but it just keeps flashing the battery icon is that normal?
