03-18-2016
10:17
18:43
03-18-2016
10:17
18:43
How can I factory reset my alta?
04-27-2020 07:08
04-27-2020 07:08
None it does not have one
06-09-2020 22:41
06-09-2020 22:41
how do i restart and recalculate my fitbit alta?
06-15-2020 18:21
06-15-2020 18:21
I dont see one on mine either
09-20-2020 08:51
09-20-2020 08:51
I recently bought an Alta on Amazon. But the charging cable does not have a button on it and the other end has dots but not the Fitbit logo. Is it fraudulent? My Fitbit went dark so I wanted to reset it but there is no button. Any help would be appreciated.
09-20-2020 15:18
09-20-2020 15:18
Hi, @Peggy12345 , the authentic Fitbit charging cable has a little button for restarting. If you bought this from Amazon I would suggest getting in touch with them. You can also check with Fitbit Customer Support on Contact.fitbit.com who can confirm if your device is counterfeit. I would do this as soon as possible. Amazon will likely accept a return if the device is not as described, but Fitbit, obviously, will not honour a warranty if you don’t actually have one of their legitimate devices!
The Alta is now an older Fitbit device. If yours turns out to be counterfeit, I can strongly recommend the new Inspire 2. Alternatively, since it is now discontinued, you may be able to get some good deals on the earlier Inspire / Inspire HR - also excellent devices. But do make sure they are genuine. Fitbit will continue to support older devices, if they are real Fitbits and bought from authorised sellers.
I hope this helps. Welcome to the forums!
10-06-2020 16:40
10-06-2020 16:40
Hey, if you want to give you Fitbit Alta away, will the new owner have access to your personal data?
10-07-2020 00:48
10-07-2020 00:48
Hi, @lornaaucoin , no personal data is stored on the Alta itself - it is all only on your Fitbit account, so you can safely give your Fitbit away.
10-12-2020 00:43 - edited 10-12-2020 00:47
Have tried this (pushing the button 3 times within 8 seconds) a few times now, and it's not resetting. It is still showing the wrong time and date.
Trying to get back to using my Alta again after a long hiatus, so would like to resolve this before I give up.
10-12-2020 01:54
10-12-2020 01:54
Hi, @rahelab restarting your Alta will not update the date and time - after restarting you will need to sync your Alta before the time and date can update. To sync open your Fitbit app, click on the Alta icon and find the “sync now” setting.
If you are having trouble syncing, you should first make sure your app is up to date and try logging out and logging back in again.
If you need more help with syncing please post again letting us know what device you use to sync your Fitbit.
10-24-2020 17:57
10-24-2020 17:57
What if you don’t have a pc computer. I only have a mac.
seidlek
10-25-2020 08:54
10-25-2020 08:54
What’s the solution only have a Mac computer?
10-25-2020 09:21
10-25-2020 09:21
Hi, @Seidlek , here’s some information about using Fitbits with a Mac computer that you might find helpful:
https://www.imore.com/how-set-and-start-using-your-fitbit-mac
01-11-2022 17:22
01-11-2022 17:22
Did NOT work for me.
01-13-2022 10:22
01-13-2022 10:22
02-05-2022 09:09
02-05-2022 09:09
My fitbit alta app shows battery is full when n taken off charger it shuts off doesn't come back on
