02-19-2019
02:00
18:17
02-19-2019
02:00
18:17
My Alta just crashes out about every other day right around the time I get to 10,000 steps. I have to plug it into the cable and "charge" it to get it to restart even though it seems to have a charge. Anyone else having this issue? Is there a solution?
Moderator edit: Updated title for clarity
12-03-2019 00:00
12-03-2019 00:00
12-03-2019 05:53
12-03-2019 05:53
Mine went downhill pretty quickly after freezing, it would just stop working. I tossed it as I don't have the receipts. I'll purchase another brand.
02-24-2020 08:27
02-24-2020 08:27
Did this issue get resolved? I have re-set up my Alta 3 times now and am still experiencing the issue. Such a disappointment!
02-24-2020 09:55
02-24-2020 09:55
No it didn't there is a fault with all of them fit bit will offer you a discount of another style
02-29-2020 02:10
02-29-2020 02:10
My wife alta hr shut off after 10,000 steps. have to reconnect and charged.
Now i am using the alta hr as a paper weight. The most expensive one i ever had.
Can fitbit do something for me?
02-29-2020 02:29 - edited 02-29-2020 02:31
The solution best suited for most consumers at this point is the Apple Watch or another brand. I don't typically support Apple, however, in this case failures in FitBit customer service and product support warrant moving on.
02-29-2020
11:15
19:46
RicardoFitbit
02-29-2020
11:15
19:46
RicardoFitbit
Same thing here I’m in like my 6th replacement within 6 months and have had no help just keep getting replacements that do not work properly. Even with buying extended warranty i cannot get any good device.
Moderator Edit: Formatting
07-06-2020 06:00
07-06-2020 06:00
Same started happening to me a couple of months ago, mostly right away at the reaching point of the 10,000 steps when the fireworks shows up; so I set my device to 20K and it worked Ok for a week, but now again is happening at the same 10K and without having the fireworks even though my battery was up to 50% or 70%...so frustrating...
07-20-2020 16:21 - edited 07-21-2020 13:47
Same problem. Is it not possible to push out a firmware fix?
Judging from the quantity of posts by Fitbit Alta owners and the fact that the issue came on at a certain point (it never affected my wife's Fitbit Alta when she was using it five years ago but now is affecting my daughter's new Fitbit Alta), this does seem to be an error that might be fixed with a firmware update.
Even though the Alta has been retired, assigning an engineer to find a fix would certainly be welcomed by the Fitbit community.
07-23-2020
18:49
19:45
RicardoFitbit
07-23-2020
18:49
19:45
RicardoFitbit
I am having the same issue & am getting extremely frustrated that this is happening to so many other people & nobody can explain?
07-23-2020 21:46
07-23-2020 21:46
fitbit will be losing market share if they opt not to listen to customers.
If they do not want their customers, we can always go elsewhere.
There is a need to resolve the issue asap.
We are nice community, patience and gracious to wait.
But a solution need to be given, if not.. one to one exchange for another model with a minimum charge.
08-01-2020 11:39
08-01-2020 11:39
Same problem here. Halfway through a long hike I hit my goal, fireworks, then dead. I’m going to try setting it way above my goal - I don’t need the fireworks!
09-25-2020 04:03
09-25-2020 04:03
hey, i have the same problem and done some research i came across this video and after a week or so my fitbit has not crashed. might help you or anybody who has this issue.
https://www.youtube.com/watch?v=gZoQrhFjd_o
this is the video.
09-25-2020 04:11
09-25-2020 04:11
hey there i have the same issue as you. i found this video and this has fixed the issue for me.
10-09-2020 19:29
10-09-2020 19:29
My Alta HR does the same. It crashes midway through displaying the goal celebration. I wish FitBit would fix this bug. It is very annoying.
10-19-2020 04:48
10-19-2020 04:48
It seems also that do the same when vibrate, for example if it's sync to receive messages from the phone...I'm so frustrated already...
07-09-2022 18:51
07-09-2022 18:51
Same issue
06-29-2023 12:50
06-29-2023 12:50
Happening to my Alta HR now too ☹️ Does it just seem to be the Alta that this issue affects? Don’t wanna go and buy a different model only to have the same issue!
