07-26-2020
17:55
19:01
07-26-2020
17:55
19:01
My Alta HR is charged and the green lights are flashing but there's nothing on the screen; it's black. I've tried resetting, charging it overnight, standing on my head and chanting, etc., but I can't get it to display anything at all. I welcome anyone's sage advice.
Thanks!
07-28-2020 08:37
07-28-2020 08:37
How old are your fitfib’s
Best Answer07-28-2020 11:41
07-28-2020 11:41
Same here. Recording activity on the app but screen is blank
Best Answer07-28-2020 11:54
07-28-2020 11:54
Same problem. I'd like to know if it can be reset, or just thrown out.
Best Answer07-28-2020 12:12
07-28-2020 12:12
Contacted Fitbit and looks like it's too bad, too sad, since it's no longer under warranty (I bought it in January 2019). Best they could do was offer me a 25% discount on a new one. Don't think I'll bother.
07-28-2020 14:18
07-28-2020 14:18
Tried resetting mine several times today. No joy.
Best Answer07-28-2020 14:19
07-28-2020 14:19
Got mine in 2018 so no warranty for me either. I'll get another one eventually.
Best Answer07-28-2020 15:46
07-28-2020 15:46
Mine is the same, however on the app it also says “no device found” And won’t sync. It’s a bit disappointing to have to throw out a device that is less than 2 years old!?
07-29-2020 10:42
07-29-2020 10:42
Hi, My Fitbit Alta HR also stopped charging and turning on at all. I reset it several times over the last three days by holding down the button for 3 seconds over and over. It worked twice, but today won't turn on at all. It is about 2 years old. Please advise.
07-29-2020 13:37
07-29-2020 13:37
Oddly enough mine is the same age so out of warranty! Still tracking activity to the app but no display. Resetting didn't help.
Best Answer07-29-2020 13:39
07-29-2020 13:39
Very odd that we're all having this issue at the same time with these fitbit. Do you think they're only built to last 2 years so you'll buy another or is that overly cynical?
07-29-2020 13:48
07-29-2020 13:48
Mine went blank yesterday, stopped recording steps. Recharged it last night, this morning it worked for a short time, now it's black as night.
Do you think it's possible Fitbit decided to shut this model down for everyone?
07-29-2020 15:41
07-29-2020 15:41
Best Answer07-30-2020 08:15
07-30-2020 08:15
From what I can see posted here it's b very odd we're all having this issue with the same model fitbit at the same length of time since purchase.
07-30-2020 08:18
07-30-2020 08:18
Best Answer07-30-2020 08:24
07-30-2020 08:24
Best Answer07-30-2020 13:29
07-30-2020 13:29
Yep. My Alta HR died a year and a half afterwards, too. When I contacted support they offered me the same 25%. Considering that Fitbit is the leading company for fitness trackers, you'd think their products would last a bit longer.
07-30-2020 13:32
07-30-2020 13:32
@SunsetRunner wrote:Very odd that we're all having this issue at the same time with these fitbit. Do you think they're only built to last 2 years so you'll buy another or is that overly cynical?
No, that's certainly not cynical. Yes, I definitely think they're only built to last 2 years [or less] so we come back and buy another.
Best Answer07-30-2020 15:07
07-30-2020 15:07
07-30-2020 15:23
07-30-2020 15:23
