Fitbit Alta HR - switched off and won't charge
Hi my Fitbit Alta HR will no longer charge.  I plugged it in to charge as normal and got nothing.  I've moved plugs, plugged it in directed via the USB, bought a new charging cable and pressed the button on the USB end of the cable with no luck.
Prior to this it was working perfectly and held its charge for a reasonable amount of time.
Any ideas or suggestions welcome.
Thanks
A
1 REPLY 1
Hello @AnnieMcT Welcome to the Community Forums!. Thanks for trying to troubleshoot this inconvenience and for the information you provided.
I would like to confirm if besides the troubleshooting steps you've tried, if you completed all the suggestions provided in the following link:
Why isn't my Fitbit device's battery charging?
Please keep me posted if the inconvenience persists.
Wilson M. | Community Moderator, Fitbit.
