11-28-2017
13:31
18:17
11-28-2017
13:31
18:17
In last couple of days my Alta battery is draining within a couple of hours where previously lasted several days. Have tried resetting but still same problem.
Moderator edit: Updated title for clarity
07-11-2020 17:08
07-11-2020 17:08
I ordered my fitbit alta HR on july 16th, 2019. Past couple of days it only holds a charge now for 1 hour and dies. I did the reset a couple times, let it die then charged to 100% and nothing worked. I bought a Fitbit Charge HR today but honestly don't like it as much (band is so big!). I didn't realize until now that I haven't even had my Alta HR for a year yet until it died like this.
Best Answer07-14-2020 06:52
07-14-2020 06:52
I don't have a fix for this, but my Alta is doing the same thing. Mine is 2 years old. It used to last a week between charges, now it is hard to keep it charged at all. When I go to plug it in, it shows that it should still have a charge. Very frustrating.
10-03-2020 07:52
10-03-2020 07:52
So has a fix for this ever been found?
Best Answer10-03-2020 14:14
10-03-2020 14:14
The best info I could find was that the batteries have a limited life. I ended up having to buy a new Fitbit!
Best Answer10-03-2020 15:46
10-03-2020 15:46
Went through customer service which took forever, but they gave me a replacement new one of the Alta
Best Answer10-03-2020 17:39
10-03-2020 17:39
Looks like I’m in same place as you. I guess i. Will look into buying a new one.
Best Answer10-03-2020 17:40
10-03-2020 17:40
I think by th w looks of it the answer is buy a new one😩
