04-15-2019
13:23
18:17
04-15-2019
13:23
18:17
My Fitbit is nearly 3 years old and working fine then suddenly the display was lost, activity tracking and synching and although on checking the battery is full. Display and synching only possible when the Fitbit is plugged in through charger
06-22-2019 00:43
06-22-2019 00:43
Apparently, there's no solution to this when you are already out of the warranty period. 😔
Best Answer06-22-2019 12:07
06-22-2019 12:07
I have that same exact problem.
Best Answer06-22-2019 14:30
06-22-2019 14:30
Me too. It works for about one minute after I unplug it but it goes dark again. I just got it a few weeks ago and I’ve tried restarting it but it doesn’t work.
Best Answer06-23-2019 10:41
06-23-2019 10:41
I have in the same situation too. It won't respond to any of my TAPS at all. Only when it's charging I can see something but it won't work out for me.
Best Answer06-24-2019 23:07
06-24-2019 23:07
I just bought an Alta from Fb market place and it turned on for a bit but now I can’t get the screen to show up at all...tried all the troubleshooting tips...the charger came half broken so I’ll try a new one to make sure, (if I can even find one) but so far I’m rather disappointed...
Best Answer06-25-2019 08:26
06-25-2019 08:26
AM HAVING THE EXACT SAME ISSUE WITH MY ALTA & my FITBIT CHARGE HR is falling apart - even tho it is my newest FITBIT. This is the 2nd CHARGE I have had the same problem with- the band is separating from the device, the little black piece that the charger plugs into to hold the cord in place while charging came off- seriously disappointed in how long these are lasting compared to my original FLEX.
Seriously thinking of giving Garmin a try - pricier, but in the tie I have gone through 4 fit bits, my daughter is still on her 1st Garmin,
Best Answer06-25-2019 11:43
06-25-2019 11:43
My Fitbit Alta isn’t working correctly either. Charge is fine. I’ve re-set, I’ve syched it, I’ve made sure it was charged. It’s past the warranty so I imagine there’s not much I can do but it would be nice to know what else can be done.
Best Answer06-25-2019 18:26
06-25-2019 18:26
I am experiencing the same issue, the display show the time, everything works as long as it's on the charger. From reading the posts, it sounds like this happens a lot. My fit bit is about 3 years old.
Best Answer06-26-2019 00:53
06-26-2019 00:53
I am having the same problem so I came on to the forum hoping for an answer but I am disappointed to find that there doesn’t seem to be a solution. My Alta is out of the guarantee period too so it looks like we are all in the same position. It’s not a good advert and I won’t recommend them in future
Best Answer06-26-2019 03:33
06-26-2019 03:33
Just got mine in February and it was doing this by May! Help! Completely dissatisfied!
Best Answer06-26-2019 04:47
06-26-2019 04:47
Mine is doing the exact same thing. Would you be able to put a ticket in for me as well?
Best Answer06-26-2019 05:27
06-26-2019 05:27
There is something seriously wrong with the Alta, whether caused by the recent software update or not, which Fitbit will not address.
Replacing the Alta with another Alta that will just fail in the same manner is not a solution. Why isn’t Fitbit giving us a real answer?
They’ve lost a long-time customer, and I know many others are jumping ship as well.
06-26-2019 05:39
06-26-2019 05:39
Hi-
I've had my Alta for about 6 months and it has started to quit working (blank screen not responding to taps, despite a full battery charge), after I plug it in, it resets to the last time I synced and requires a resync after which it seems fine. However it is happening more frequently. Twice in the last 24 hours and is currently not working.
I'd like to get this figure out before it is out of warranty.
Best Answer06-26-2019 06:03
06-26-2019 06:03
Best Answer06-26-2019 06:08
06-26-2019 06:08
Taffydog -
Thanks for the advice, good to know there is a 2 year warranty. However it was a Christmas present. I don't have the receipt or know where it was purchased.
Best Answer06-26-2019 06:22
06-26-2019 06:22
06-26-2019 07:05
06-26-2019 07:05
This is my second Alta and I am having the same issue they will work for a short time then shut down and you have to replug them in. I have tried resetting them and the issue continues. I am about to give up as when they shut down they do not track.
Best Answer06-26-2019 07:08
06-26-2019 07:08
are both brand new and work for varing amounts of time before shutting down
Best Answer06-26-2019 10:29
06-26-2019 10:29
I am facing the same issue. My alta is also showing charging symbol even when it is not charging
Best Answer06-27-2019 03:59
06-27-2019 03:59
