04-15-2019
13:23
18:17
04-15-2019
13:23
18:17
My Fitbit is nearly 3 years old and working fine then suddenly the display was lost, activity tracking and synching and although on checking the battery is full. Display and synching only possible when the Fitbit is plugged in through charger
08-26-2019 08:18
08-26-2019 08:18
Same issue with my Alta and it is brand new. I called customer support and they were not able to help me 😡
Best Answer08-26-2019 08:20
08-26-2019 08:20
I tried that and it didn’t work. I think it is just a 💩 watch. So disappointed 😔
Best Answer08-26-2019 09:27 - last edited on 08-28-2019 18:44 by LiliyaFitbit
I bought mine in May from Amazon (after having had one in 2017 that stopped working in May) and now my new one is having the same issues. It is very frustrating. I did contact customer support and since its only been 3 months, they are sending me a new one but it's a pain. I should have never bought another FitBit because I should have known. I am sure the new one they send me will have the same issues.
Please consider the environment before printing this e-mail
Best Answer08-26-2019 09:44
08-26-2019 09:44
so I tried one more thing that someone had suggested and I think it worked dont want to jinx it but I plugged it in to my computer and reset it but instead of unplugging it I kept it plugged in for a few hrs and so far so good it hasnt turned off
Best Answer08-26-2019 10:03
08-26-2019 10:03
Best Answer08-26-2019 10:07
08-26-2019 10:07
Best Answer08-26-2019 14:38
08-26-2019 14:38
Best Answer08-26-2019 14:39
08-26-2019 14:39
Best Answer08-26-2019 15:46
08-26-2019 15:46
I had that issue before, but now it thinks it’s charging when it’s not.
Best Answer08-26-2019 19:09
08-26-2019 19:09
What is the life time of the Alta?
I'm having the same problem, when my Alta is connected to the charge all my steps, sleep etc are down loading but I just can't read the screen when it's unplugged which is hopeless, although the alarm is still working.
I use my Alta mainly as a watch so it's a bit frustrating, my third dress strap broke in the weekend too so I'm wondering do I just buy another device/model or a completely different brand?
some advice would be recommended from Fitbit
Best Answer08-27-2019 03:43
08-27-2019 03:43
Realy?! I have that same problem!!
Best Answer08-27-2019 05:08
08-27-2019 05:08
08-28-2019 18:39
08-28-2019 18:39
Hello all, thank you for participating in the forums. I am sorry for the delayed reply.
Thanks to all for the efforts to resolve the issue, sharing your experiences and feedback. If after following the steps to restart the tracker the issue persists, I recommend contacting our Customer Support team. They will do their best to help you and provide the options according to the Fitbit Warranty.
I appreciate everyone's feedback, I understand that this can be very frustrating, our team is always working on improving our devices and user experiences, and your comments are always welcome.
Best Answer08-29-2019 06:01
08-29-2019 06:01
My fitbit Alta has been working sporadically since I updated my app. When I plug it in it shows the battery is 3/4 full but the display does not work unplugged. If I plug it in to be charged it charges full but then it dies within a day. When I plug it back in the battery shows 3/4 full?
I have restarted multiple times but still the same problem. I must admit I had not worn it for about 2 months.
Any suggestions?
thanks
Fran
Best Answer08-29-2019 06:28
08-29-2019 06:28
08-29-2019 12:45
08-29-2019 12:45
My sister and I both have the same problem with the Alta and it seems the issues started with the last update, In both our cases the Fitbit was less than a year old.
Best Answer08-29-2019 14:08
08-29-2019 14:08
Get your $ back, if you can, because there seems to be issues with various models especially after a year or a software update.
Best Answer08-29-2019 14:18
08-29-2019 14:18
The software update seems to have bricked all the Altas and Fitbit does not seem to care.
Best Answer08-29-2019 16:13
08-29-2019 16:13
I totally agree
Best Answer08-29-2019 16:25
08-29-2019 16:25
