04-15-2019
13:23
18:17
04-15-2019
13:23
18:17
My Fitbit is nearly 3 years old and working fine then suddenly the display was lost, activity tracking and synching and although on checking the battery is full. Display and synching only possible when the Fitbit is plugged in through charger
09-17-2020 13:39
09-17-2020 13:39
My fitbit alta is also showing v21.40.02 which i understand is a battery problem. I've tried resetting it and the battery shows as charging. It then shows full battery but the screen remains black when i take it off charge. Really disappointed in Fitbit so will most probably try a different make moving forward
Best Answer09-17-2020 14:19
09-17-2020 14:19
why would you not return it for a full refund
Best Answer09-17-2020 16:59
09-17-2020 16:59
I am also having this problem My fitbit Alta only works when plugged in and it shows a full battery
Best Answer09-17-2020 17:02
09-17-2020 17:02
It happened to me just recently as well.
Best Answer09-17-2020 17:27
09-17-2020 17:27
have the same issue
Best Answer09-17-2020 17:35
09-17-2020 17:35
My fitbit is doing the same. it is around 3 years old as well Talked to customer service and he said the warranty is only a year but the display will last 3-4 years. He emailed me a 35% discount on buying another Fitbit.
19:27
06:05
AndreaFitbit
09-17-2020
19:27
06:05
AndreaFitbit
Mine too...charges to 80 percent only . I woukd like a replacement. Is that possible?
Thanks.
Moderator edit: format and removed personal information.
Best Answer09-17-2020 20:36
09-17-2020 20:36
I am having the same problem. Chatted with representative but was not able to start my device off the charger!
09-17-2020 20:39
09-17-2020 20:39
My device also shows v21.40.02 and does the same thing. I wonder what that means.
09-18-2020 14:54
09-18-2020 14:54
I’ve been having this issue too and the best that Fitbit is able to offer, even though this is CLEARLY a software bug, is to offer me a 35% discount. Why can’t they just figure out what is going on in the software and send out one last hurrah! software update? (Probably because they phased out the Alta for the Inspire...)
09-18-2020 17:12
09-18-2020 17:12
Sorry, been there...just give it up because they won't do anything...the theory we bounced around is that they did it on purpose. The Altas were working too well and lasting too long...
09-19-2020 01:16
09-19-2020 01:16
Mine is also approx 3plus years old. Whenever I take it off for a shower, it won't work until I plug it into the charger, even though it was fully charged.
Now it won't sync.
09-19-2020 05:00
09-19-2020 05:00
Best Answer09-19-2020 13:05
09-19-2020 13:05
I am also having the same issue where my Alta screen just goes black. The strap has also broken so it keeps coming off my wrist 😞
Best Answer09-19-2020 14:44
09-19-2020 14:44
Best Answer09-19-2020 16:20
09-19-2020 16:20
17:05
06:06
AndreaFitbit
09-19-2020
17:05
06:06
AndreaFitbit
I am having the same issue. Alta fully charged. Display shows while on charger. Off the charger, screen goes black. Love my Alta. Please help.
Moderator edit: format.
09-19-2020 20:58
09-19-2020 20:58
Skimming through various accounts, it looks like I’m not alone. Obviously a company moving on with technology and leaving consumers out of luck except to buy new. Planned obsolescence as it goes with all companies. Let’s add to the waste of the world as there’s no money in something lasting much beyond two years.
Best Answer09-20-2020 02:06
09-20-2020 02:06
Sorry, there is no help...we're tried...
Best Answer09-20-2020 03:09
09-20-2020 03:09
Mine started doing this yesterday afternoon. Tried everything and no luck. So basically we have to buy a new one??
I've seen a lot of posts about this.
