05-09-2021 18:09
05-09-2021 18:09
My fitbit alta - keeps a charge and I've restarted it 3 times - it won't stay on?
Help 🙂
05-13-2021 15:24
05-13-2021 15:24
I’m having the same problem.
Best Answer05-15-2021 11:34
05-15-2021 11:34
Best Answer05-15-2021 13:02
05-15-2021 13:02
I've been having the same problem for the past week and a half.
Best Answer05-15-2021 13:40
05-15-2021 13:40
Same here, when I plug it in and reset it the battery shows life, as soon as I unplug from the charger it conks out. I wear mine everyday so this is very sad... I’ve had it almost 2 years and just started having issues within the last 2 weeks. Have tried cleaning and multiple resets, any ideas anyone? Was hoping for a fix and not to have to buy a new product.
05-17-2021 17:50
05-17-2021 17:50
Same here. I have restarted it several times. It will display if it is on the charger but as soon as I unplug it, nothing will display.
05-19-2021 09:45
05-19-2021 09:45
Same problem ( stops working when unplugged from charger) started today, No solution posted,yet.
Best Answer05-19-2021 19:22
05-19-2021 19:22
Same here started Monday 😢
Best Answer05-20-2021 16:19
05-20-2021 16:19
Same here; displays when attached to charger and then no action when unplugged... dead. Have tried restarting multiple times.
05-20-2021 16:49
05-21-2021 16:59
05-21-2021 16:59
The same thing started for me last Sunday. Why isn't Fitbit addressing this? Is it just to get us to buy a new Fitbit?
Best Answer05-21-2021 17:45
05-21-2021 17:45
Best Answer05-21-2021 17:46
05-21-2021 17:46
I would say yes - it is unfortunate that you can't replace batteries for these fitbits. I spent a lot of $'s buying extra bracelets that of course don't fit other fitbit models. The Fitbit alta hr/alta is not sold by fitbit anymore so you can't even buy a new one!
Best Answer05-21-2021 17:51
05-21-2021 17:51
I had an Alta HR that stopped working completely - wouldn't hold a charge. I wanted to use all the bracelets I bought so I purchased a used Alta and it worked for a day or two then stopped. When I reset it - it worked for a day. The battery was still charged but the fitbit didn't work - so I asked fitbit and this is where we are today.
I want another Alta HR - it worked great for what I wanted and I could use the extra straps I've purchased previously. Too bad the new 'version' of the Alta/Alta HR has a different bracelet mechanism so of course you can't use the Alta/HR straps.
Best Answer05-25-2021 08:26
05-25-2021 08:26
Same problem here, I also had an Aria scale that quit working after about a year and a half and Fitbit said too bad so sad. I had a Fitbit flex that lasted be a few years and decided to upgrade to a Fitbit Alta and have The same problem it charges but as soon as I take it off the charger it shuts off and I can’t get it turned back on unless I put it back on the charger. Needless to say I think my Fitbit days are over
05-27-2021 12:22
05-27-2021 12:22
Same issue here. Getting frustrated with this.
Best Answer05-27-2021 17:03
05-27-2021 17:03
I won't come out of sleep mode when tapped. I have to put it on charge to wake it. I noticed it happens when battery reaches 75%. Also the battery icon on the display looks lined as if charging when it is not on the charger.
I wonder if this is a software bug 🤔
Best Answer05-27-2021 19:23
05-27-2021 19:23
