03-20-2016
17:55
18:43
03-20-2016
17:55
18:43
08-09-2016
09:49
- last edited
3 hours ago
08-09-2016
09:49
- last edited
3 hours ago
@SamSam22 Thanks for joining our Community! If you have confirmed the proper way to charge your Alta and followed our recommended troubleshooting steps, the best way to solve this is getting in touch with support. I'm sure they will be glad to evaluate your case and options.
Keep me posted! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
03-20-2016 19:48
03-20-2016 19:48
I had the same problem, kind of. My alta would vibrate but there was no screen. No matter what I did. I ended up calling and they are sending me a replacement. I did notice that I had to push a little harder to hear a click when it connected to the charger. If your Alta is vibrating but your getting nothing on the screen you probably need to call support or exchange where you purchased.
13:52
- last edited
4 hours ago
03-21-2016
13:52
- last edited
4 hours ago
Hey hey hey @Roec153 welcome to the Forums! Don't worry, that's the way Fitbit Alta was designed. If you are sure the golden contacts from the tracker and charger are aligned and it is still not charging, I recommend checking the recommendations on this thread about "Alta unable to charge".
@Heatheranne79 I'm glad to hear that support took care of your inquiry. Enjoy your new Fitbit Alta and keep the stepping up!
Let me know if you have any other question! See ya! ![]()
Best Answer03-21-2016 14:17
03-24-2016 13:36
03-24-2016 13:36
You are welcome @Roec153! I'm glad to hear that support took care of your tracker. Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Best Answer06-12-2016 15:48
06-12-2016 15:48
Same problem as below. My fitbit Alta came with three copper charging dots and the charger has only two, so it will not align. Any suggestions?
06-22-2016
06:59
- last edited
4 hours ago
06-22-2016
06:59
- last edited
4 hours ago
Hey there @artsong9! That's the way Fitbit Alta was designed, it should align properly. Please check this post of mine with an image about connecting your tracker.
I noticed that you are new in the Community, welcome! I encourage you to join us at Discussions board, there you can share your story, find some fitness tips, recipes and more! Give it a look!
Enjoy your new Alta and keep the stepping up! ![]()
07-02-2016 08:38
07-02-2016 08:38
I've had that same problem. Except, I got my fitbit a couple weeks a go and then last week it just stopped charging.
13:15
- last edited
3 hours ago
07-03-2016
13:15
- last edited
3 hours ago
It's too bat to hear that your Alta stopped charging @moniquevilla13, a few factors can cause your battery to stop charging:
If your tracker still won't charge, contact Customer Support.
Last but not least, welcome to the Community!
See you around! ![]()
08-05-2016 01:58
08-05-2016 01:58
Just bought an alta. It won't charge. I've looked at youtube and read instructions to ensure that I am doing things correctly. I've checked my power source. Nothing wrong my end. Disappointed!
08-09-2016
09:49
- last edited
3 hours ago
08-09-2016
09:49
- last edited
3 hours ago
09-19-2016 17:21
09-19-2016 17:21
09:00
- last edited
3 hours ago
09-20-2016
09:00
- last edited
3 hours ago
That's too bad to hear @Coloradocarrie, since you have already contacted support, I recommend following up with them. In order to get a faster response, you can contact them via phone at (877) 623-4997 M-F 4am-8pm // Sa,Su 6am-5pm (PT) or via chat, just make sure of reference your case number. I'm sure they will be glad to assist.
Welcome and keep me posted!
Best Answer09-29-2016 08:27
09-29-2016 08:27
I was having the same issue.
I was able to charge after the first step (cleaning the contacts with a toothpick). However, this is the second time I have had to do that within 30 days.
Is this an engineering issue that is planning to be addressed?
Thanks!
08:48
- last edited
3 hours ago
10-03-2016
08:48
- last edited
3 hours ago
Welcome to the Community @MixInASalad! If the issue persists after following our recommended troubleshoot, the best step is getting in touch with support. I'm sure they will be glad to assist.
Keep me posted!
Best Answer10-03-2016 09:56
10-03-2016 09:56
Thank you!
Best Answer10-06-2016 08:44
10-06-2016 08:44
You are welcome, it's always my pleasure! I encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more! Give it a look!
Best Answer10-15-2016 23:08
10-15-2016 23:08
I'm having the same issue. My Alta won't charge. Cleaned everything. Still not charging. What do I do now? I just bought it 2 months ago. I haven't worn it for a month.
10-17-2016
19:09
- last edited
3 hours ago
10-17-2016
19:09
- last edited
3 hours ago
Welcome to the Fitbit Community @RiDeZ! Have you tried @CindyFitbit's tips on her previous post? If so, please get in touch with Support for further help.
Good luck and keep me posted with the outcome! 😉
10-26-2016 21:51
10-26-2016 21:51
I have had the exact same problem. Bought 2 months ago. Used successfully for 6 weeks. Left in drawer for 2 weeks. Now it doesn't charge. Nothing on display, no buzz when attached to charger. Help!
