03-20-2016
17:55
18:43
03-20-2016
17:55
18:43
10-27-2016 05:58
10-27-2016 05:58
Welcome to the forums @unaleed, if you’ve already tried to restart your tracker at least a couple of times and all of the steps mentioned above in this thread, I do recommend that you get in touch with the Customer Support team for further assitance, they will let you know how to proceed. I hope this helps.
03-07-2017 21:31
03-07-2017 21:31
You just line it up and it buzzes.
Best Answer03-08-2017 22:34
03-08-2017 22:34
Yet the reset method a few times with the charger button but majeure Bluetooth is on on your phone.
Best Answer03-09-2017 11:57 - edited 03-09-2017 11:58
how long does it take to get the fitbit to u?![]()
Best Answer03-29-2017 13:20
03-29-2017 13:20
Well I got my replacement Alta today because my other Alta was having to be charged everyday. This is my last try with Fitbit. I've had the Flex and the Charge and they all have the same problem.
18:08
16:01
LucyAP
03-30-2017
18:08
16:01
LucyAP
Good! If this one doesn't work, contact Fitbit support and tell them about your problem. Ask for an Alta HR. It is the newest and most likely will work the best. Hope this helped!
Moderator edit: format
04-28-2017 19:16
04-28-2017 19:16
I have an AltaHR, brand new only two days old and it will not charge at all! Tried various outlets in my house, have all the battery sucking options turned off, have gone through customer support and they keep telling my it is "fine" and the battery is "not drained" but when I unplug it and double tap the screen NOTHING. I am really frustrated...they don't see to want to back their product.
Best Answer04-29-2017 04:58
04-29-2017 04:58
Best Answer05-15-2017 18:29
05-15-2017 18:29
I an in my second Alta HR Fitbit. My first one would not charge at all. Fitbit sent me a second one. I have only had this one for a couple of weeks now and now this one won't charge. I have tried resetting it without any success! I really don't want to be on terminal hold with Fitbit again, but I have no choice! My charge HR never had this problem. The Alta HR is disappointing at best!
Best Answer07-06-2017 08:41
07-06-2017 08:41
Thank you for the information as you said the charging point got a liitlle bit dust so i cleaned it up and its working
Best Answer08-06-2017 01:42
08-06-2017 01:42
It's will charge do u know the button near the computer press that 5 times and wait 10 seconds then push it for 7 times and leave it
Best Answer08-06-2017 14:43
08-06-2017 14:43
Best Answer09-15-2017 09:59
09-15-2017 09:59
Just got mine today....same problem. Sadly, I ordered it from Fitbit directly....so I cannot just run and exchange it for a new one. so disappointed.It will be days before I can get a new one.
Best Answer09-16-2017 19:27
09-16-2017 19:27
Best Answer12-04-2017 09:40
12-04-2017 09:40
I had (still have actually) a FitBit Alta (that my son is using) and today it was no longer detected on my laptop when we plugged it in to charge.
We tried the reset, and spent some time with Jose on a support chat to try to trouble shoot it. We tried a number of things and we have 2 options to remedy the problem. The first we'll know in about a week to see if it works. I can say that the help was fantastic and Jose even said they would follow up with an email for me to tell them how it's working. I have to say that good support and even follow up is hard to find in a disposable world that we live in. Keep it up.
Best Answer04-22-2018 19:31
04-22-2018 19:31
Ok so I just got my fitbit and of course I doesn't work! I have tried to plug it up but, it doesn't work. I'm not really sure what the problem is, I have cleaned it and everything. Can you clean it with alcohol? Like rubbing alcohol.
04-23-2018 06:29
04-23-2018 06:29
Best Answer04-27-2018 11:38
04-27-2018 11:38
Hi everyone and welcome to the new users!
Thanks for all the troubleshoots that you have performed. I would like to cover as much as possible so my best advise is following the troubleshoots listed on this article. If by any chance you're still having trouble please let me know so I can further assist you.
Keep me posted!
Best Answer05-09-2018 11:00
05-09-2018 11:00
I too have problems charging my Alta HR, this is the worst set up for charging you have to fool with it for 5 to 10 min to get the charger connected correctly.Then if you touch or bump it while it is charging it becomes unconnected, and stops charging. I would definitely buy something else next time.
Best Answer05-11-2018 10:47
05-11-2018 10:47
I feel like I was lucky compared to most of the folks in this community: Fitbit Alta worked from November 2016 to May 11th 2018.
I had to use the restart on a couple of times since I had the Fitbit and that always worked to allow it to respond.
Last night it stopped for an unknown reason. I was able to restart it this morning but then it died about 2 hours later.
Tried the restart process and now it will not even indicate anything on the screen when connected to the charging cable. Tried cleaning the charging posts. (tested the alcohol - it burns really good)
Extra steps to confirm good cable and good connection:
Conclusion:
Battery failure in the Fitbit
Solution:
Dig a hole in the backyard and bury it deep. Buy another brand tracker - real cheap one so that when you bury it in the back yard you are not out as much $$$$.
Good luck to all others with the frustrations of owning a Fitbit Alta.
