03-20-2016
		17:55
		18:43
		03-20-2016
		17:55
		18:43
05-12-2018 17:28
05-12-2018 17:28
Hi!
I'm having this exact sample problem! My Fitbit isn't charging, syncing, restarting, or responding to any taps and double taps. Started using it on April 15th, 2016, stopped working May 11th, 2018.
Is this fixable? Is it due to the newest app update? Or is it a complete loss and I can get a replacement?
Look forward to hearing from you soon! (Already lost 2 days worth of steps!)
Best,
Kristina
 Best Answer05-15-2018 12:24
05-15-2018 12:24
 Best Answer07-17-2018 12:28
07-17-2018 12:28
Trying to charge my fit bit Alta and a ! Comes up… Any ideas?
 Best Answer07-17-2018 19:04
07-17-2018 19:04
 Best Answer09-21-2018 14:10
09-21-2018 14:10
I have had mine for a year in December, it worked just fine til the other night. I went to plug it in and it started acting up. I decided to look up and see if there was a way to restart it and greatly there was. I followed the steps and now it is charging,but have to charge it through my laptop. Plug the fitbit onto the end like normal,then press the tiny circle on the big part that connects to the computer and do that 3 times in a row. That will reset the fitbit ONLY will not effect goals,process,etc. If that dont work i would suggest getting ahold of customer service and saying everything going on and they should be able to send a replacement.
 Best Answer09-29-2018 07:04
09-29-2018 07:04
The same exact thing is happening to me I just bought it yesterday won’t charge to pins against three pins on charger I’m taking it backI guess I don’t know what else to do
 Best Answer10-01-2018 12:30
10-01-2018 12:30
My fitbit battery only last a couple hours... what can I do?
 Best Answer10-01-2018 13:13
10-01-2018 13:13
 Best Answer07-22-2019 16:48
07-22-2019 16:48
I've been using my Fitbit Alta for some time now. All of a sudden it just went blank, won't take a charge and when I tried to charge it, the device became very hot. I'm unable to restart it using a computer as my charger doesn't appear to have the "button" to press 3 times in 30 seconds.
My fitbit also has 3 prongs and my charger has two - it's always, easily, taken a charge.
 Best Answer05-26-2020 00:07
05-26-2020 00:07
Really? Your solved answer is telling us to contact customer support?
02-19-2022 09:34
02-19-2022 09:34
Can i please get some communication here, i have had very good experience with fitbit, im on my 2nd fitbit and it has this problem. I look very well after my fit bits but even when i run into a problem like this i never get the warranty i am legally bound to . Im not trying to start an argument but i feel violated because i spent so much money and now i need to do so again , can i please get some professional help to get a replacement that , i also needed a replacemet for my screen and was shocked when i found out i needed to pay even though in the remedies terms of service it states " warranty period of 1 year from purchase, if a defect arises and a return authorisation request is received by fitbit within the applicable warranty period , fitbit will, at its optionand to the extent permitted byvlaw either (1)repair the product at NO CHARGE, using new or refurbished parts or (2) replace the product with a new or refurbished product" i did not receive a right to a repair or a right to a new product. look like i said i dont want any problem i just want a replacement . I am from south africa and need my fitbit for hikes and calorie checks and im going a whole 3 months now with no news and no solutions
