01-10-2018
11:47
18:17
01-10-2018
11:47
18:17
My Alta fitbit was working just fine and just this past week, it will not hold a charge. 2 times in one day my fitbit totally died. I was able to hold a charge for almost 2 days, and now I can't even make it 4 hours and it's almost dead. Anyone else having this issue?
Moderator edit: Updated title for clarity
09-20-2018 00:27
09-20-2018 00:27
Hi - having exactly the same issues with a fitbit just coming up to 1 year. Reset it yesterday and while it lasted a tiny bit longer and did at least sync, it did not last more than half a day which is less than useless. This happened very suddenly - until last friday it was giving me up to a week of charge. I will keep syncing it and charging but what are my options - will fitbit replace or do I have to go through the shop i bought it from?
09-20-2018 00:35
09-20-2018 00:35
09-20-2018 02:42
09-20-2018 02:42
09-21-2018 10:10 - edited 09-21-2018 10:11
what information exactly do you need? I already did it.
Could you please take a look what is going on with my tracker?
thank you
09-23-2018 15:30
09-23-2018 15:30
I can't even get mine to buzz and restart anymore. It buzzed a couple of minutes ago, but now nothing. I purchased the Fitbit on Amazon, new, on 2/20/18, so should still be under warranty.
09-24-2018 06:05
09-24-2018 06:05
09-24-2018 07:01
09-24-2018 07:01
Hi there @DUMITRESC, thanks for getting back. I've escalated your case to the Support Team to see what other options are available for you at the moment. Please, keep an eye on your inbox for more instructions.
Anything else you may need, I'm always around!
09-24-2018 09:18
09-24-2018 09:18
Thanks exactly what I did. I did an online chat and my new Alta HR is in the mail!
09-26-2018 14:07
09-26-2018 14:07
Happy to say fitbit have just replaced my tracker under warranty too. Very happy...
09-27-2018
06:49
11:19
09-27-2018
06:49
11:19
Hi there @jsbofaz and @Den18 thanks for sharing your feedback.
It is very helpful to have your comments. Thanks for all the steps that you tried to fix your Alta. For all users that keep having this type of issues with the battery of your Fitbit consider these tips when you want to conserve battery life:
Also try to clean the contacts of your tracker regularly. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
If this is not helping we might have to check what is the next step with our support team.
See you around.
10-22-2018 20:06
10-22-2018 20:06
I had the same problem. I was wearing it for days at a time and suddenly it completely died. I can't get it to charge enough to even take it off the charger. Within hours it's dead. I use it for an alarm clock. Picked out up of the charger at 10 pm and it was dead by the time my husband came to bed at 1 am
10-31-2018
12:33
11:19
10-31-2018
12:33
11:19
Nice to see that you're digging into the Forums @Dawentzel, let me give you a warm welcome to our Community.
Thanks for your attempts to help your Fitbit Alta. I'd suggest to perform a restart on your Fitbit and try the steps on the post above. Have you tried to clean the contacts of the charger?
I'll be around.
11-19-2018 17:11
11-19-2018 17:11
Having the same issue as everyone else here. My Alta is not keeping the charge. I got my Alta at the end of 2016. I even tried calling fitbit, but didn't get any help from them also. Really disappointed in the service.
11-20-2018 01:47
11-20-2018 01:47
My husband is having exactly the same issue. The device just died after a very short time. It's so frustrating.
11-21-2018
13:35
11:19
11-21-2018
13:35
11:19
Hi @jainD, welcome to the Forums!
Thanks for the feedback and for reaching out the Forums. I've contacted out support team, they will reach you out shortly with more information about your options.
@MrsKamar nice to see you here. Have you tried the steps above? Please confirm if this is helping your husband's tracker.
I'll be around.
11-27-2018
10:06
12:20
YojanaFitbit
11-27-2018
10:06
12:20
YojanaFitbit
I tried this restart 3 times, and my fitbit alta still does not hold a charge. I find this so frustrating, because this is like my 4 fitbit, and they all seem to die after a year! Oddly, right after the warranty expires... I won't be buying another one. Guess it's time for me to switch to the apple watch. Sick and tired of the same crap happening with this crappy product!
Still didn't work.
11-27-2018 10:24
11-27-2018 10:24
12-05-2018
15:01
11:19
12-05-2018
15:01
11:19
Welcome to the Forums @anday2018. Thanks a million for the suggestion @Littlewolf21214!
If you already tried all the suggested steps, it will be time to escalate this with our support team and they will further investigate this issue.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on what you share here.
Please keep me posted.
02-26-2019 14:23
02-26-2019 14:23
I'm having the same problem. My Fitbit Alta is 2 years old, I've purchased another Fit Bit Alta charger, I've Google'd every 'fix', I've done all the button-holding and second-counting, and nothing. Four hours is all I get. When the charger's plugged into the USB port in my computer, or synced on my iPhone, the battery icon shows Full. On my Fit Bit it indicates very nearly full. I seriously don't want to spend money on another one. So annoying!
02-26-2019 18:52
02-26-2019 18:52
