03-23-2021 14:40
03-23-2021 14:40
The alta will turn on and sync when on the charger. Then taken off the charger it will work for about 5 hours then the screen won't turn on and track any steps that I take. I put it back on the charger and it will sync up and say it used battery life. I tried restarting it with the button on the charger 3 times and still the same thing happens? Is there anyway to fix this?
03-25-2021 05:50
03-25-2021 05:50
Hi @Cahilde No, I think your Alta is dying. If restarting doesn't change this strange behaviour then there is nothing else you can do, I'm afraid. Sorry
Helen | Western Australia
