10-28-2019
00:26
18:17
10-28-2019
00:26
18:17
My fitbit alta wont turn on anymore. I plug it in and its fully charged and so I'll go to put it on and then it will 'sleep' but not turn back on. But whenever i plug it in it says its charged. Ive restarted it and still won't fix the problem. What can i do.
10-28-2019 06:51
10-28-2019 06:51
Hi @Hatcher if restarting it several times hasn't revived it, more than likely the Alta's internal battery has died. Fitbits do a lot while they are being used and just like any other non-replaceable battery device, it eventually stops working.Might be time to look at upcoming sales for a new Fitbit. The Inspire series is much like the Alta series.
10-29-2019
14:48
09:56
10-29-2019
14:48
09:56
Hi @Hatcher, welcome to the Community Forums!
Thanks for bringing this to my attention and for troubleshooting your device prior to posting too. Let me share with you that our Customer Support team was contacted on your behalf to provide you with further assistance regarding the difficulties you're currently experiencing. That said, please keep an eye to your email inbox because they'll be in touch with you pretty soon.
In the meantime they contact you, let me know if you have any additional questions.
@Odyssey13 Thanks for the information that was shared in your post, the willingness to help is always appreciated here in the Community Forums.
See you around.
01-14-2020 05:28
01-14-2020 05:28
This is my exact problem. Fitbit help!
01-17-2020
20:13
09:56
01-17-2020
20:13
09:56
Welcome aboard @emmamcnealy, sorry for the delayed reply.
Thanks for bringing this to my attention. I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation
Let me know if you have any additional questions.
01-18-2020 08:42
01-18-2020 08:42
01-18-2020 09:31
01-18-2020 09:31
I have the same issue. Of course I am 18 days past the 1 year warranty!
01-23-2020
20:03
09:55
01-23-2020
20:03
09:55
Hi @Mjjf, welcome to the Community Forums. Your reply is appreciated @emmamcnealy. Sorry for the delayed reply.
@emmamcnealy Thanks for taking into consideration the steps that were shared on my previous post, I'm sorry to know that you're still experiencing the same issue. I'd like to let you know that our Support team was contacted on your behalf for them to provide you with further assistance. Please keep an eye to your email inbox because they'll be in touch with you soon. Same for you @Mjjf, they'll be in touch with you in a timely manner.
08-17-2020 18:55
08-17-2020 18:55
I'm having the same problem. I actually own two fitbit altas (one was a gift) and both are able to be fully charged but turn off after they are off the charger. I've tried restarting them multiple times but that hasn't helped either. And they keep the charge too, when they're put back on the charge the battery appears to be full. Why won't either one stay on?
08-17-2020 20:43
08-17-2020 20:43
08-17-2020 20:52
08-17-2020 20:52
Great news @Mjjf ! Fitbit does take each case individually, so it is always worth asking them. Keep on stepping!
08-18-2020 13:37
08-18-2020 13:37
Hi, my Fitbit has suddenly stopped working today. It is charged and I have tried the reset three times but no change. Is there anything else I can do?
08-18-2020 14:13
08-18-2020 14:13
Hi, my Fitbit won’t turn on. I have tried to reset it three times but this hasn’t worked. I posted this on this forum to see if there is anything else I can do. Strangely it did suddenly turn on and synced with the app but has now turned off again with just a black screen. What should I do?
08-18-2020 14:30
08-18-2020 14:30
This has been the case for me for several months and the past 3-4 days it has increased. Since they dropped the Alta I don't expect them to do anything about the problem or even respond really. I'm so frustrated because I loved my Alta and don't really care for the other trackers available now. I will probably replace mine with a Garmin.
08-19-2020
07:53
09:55
08-19-2020
07:53
09:55
@Sizzlejr @clairebr @LyndiVM Welcome to the Fitbit Community! It's great to have you here!
Sorry to hear that your Alta isn't working correctly and thank you if you have already troubleshooted this issue. @Sizzlejr @clairebr I have created a ticket so our Support team can further assist you via email.
@LyndiVM you don't mention if you have tried any troubleshoots and I don't have many details from you so I don't know if this may be a battery or screen issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
@Mjjf really happy to hear that our Support team was able to provide a replacement and that you are back on track with your daily activity.
Let me know how it goes.
08-19-2020 11:42
08-19-2020 11:42
08-20-2020 05:12
08-20-2020 05:12
I am having the same issues with my Fitbit. I have charged it, the battery says full, I have tried to restart it several times. Nothing seems to work. As of last month I will have had it 1 year. I am very sad because I love my Fitbit and I just don't know what to do. Any assistance that someone could offer me would be greatly appreciated.
01-13-2022 17:34
01-13-2022 17:34
same problem
01-21-2022 16:17
01-21-2022 16:17
I am facing similar issues. My battery dies after an hour even after being charged for multiple hours
