08-10-2020
04:55
19:01
08-10-2020
04:55
19:01
So my fitbit doesn't see my heartrate anymore. It's just stuck on 110. And the light is constantly on
The other light just stopped working.
Did anyone have this issue?
Or does someone k ow how to fix it?
08-10-2020 11:29
08-10-2020 11:29
I have the same issue, but it's stuck at 101
Best Answer08-10-2020 13:39
08-10-2020 13:39
Hi @Roosvondermay & @sablhbi5
Have you attempted to restart your fitbit?
To Restart the alta please follow the below directions:
Please let us know if this was helpful or if you need additional guidance.
Best Answer08-22-2020 21:24
08-22-2020 21:24
Thanks for the suggestion. This did work temporarily. I think my Fitbit is just getting old. It seems that I need to restart my Fitbit once a week to keep the heartbeat tracker working.
Best Answer08-24-2020 13:52
08-24-2020 13:52
I have the same problem, heart rate has said 120+ all evening & it’s not. The green lights seem to be permanently on, is this right? Also it has stopped giving me the detailed sleep stages although I have not changed the position I sleep in or the tightness of the strap. I’m going to restart it now & see if that helps but maybe it’s just getting old, worn it continuously since May 17!
