12-05-2017 08:32 - last edited on 08-20-2020 20:08 by MatthewFitbit
Just got the Fitbit yesterday and set it up with a customer service rep. Today it won't display the time or other features when I tap it or move it to a display position. Will only occasionally display when it seems to be immobile for a period of time.
12-09-2017 00:45
05-12-2018 07:23
05-12-2018 07:23
I just turned my Versa off and restarted it as suggested and the results are much improved! I also learned that tilting my wrist further toward me activated the display.
One tap now opens the display.
Note: I couldn't find instructions on how to turn on the display in the 87 page manual.
Hopefully the steps and stairs accuracy will improve also.
05-12-2018 07:25
05-12-2018 07:25
Even after a restart the wrist tilt works but the tap activation is intermittent.
01-23-2019 16:02
01-23-2019 16:02
Hold down the button and make sure "screen wake" is ON
01-23-2019 18:40 - edited 01-23-2019 18:42
If the tap is not working consistantly, my guess is that you are not tspping in the right place. The Alta HR is very particular about where you tap, and where I would assume would be the best place (the centre ofbthe screen) is NOT. It works much better if you tap at the bottom edge of the screen, right where the band attaches, or even just on the band. Give that a try and see if the screen activation improves.
Edited to add - just realised you have a Versa. I assumed it was an Alta HR as you have posted on the end of a thread in the alta HR forum. You are best to post Versa questions in the Versa Forum HERE
Helen | Western Australia
01-23-2019 19:18
01-23-2019 19:18
07-12-2019 00:30
07-12-2019 00:30
Fitbit does not respond to movement by showing time
01-07-2020 09:47
01-07-2020 09:47
Thank you! This worked!
01-07-2020 09:48
01-07-2020 09:48
Hold the side button and make sure "Screen Wake" is set to "auto" not "manual". This worked for me thanks to a user above.
04-13-2020 01:49
04-13-2020 01:49
Thank you, you just saved my day 😊
11-27-2020 06:14
11-27-2020 06:14
Thanks that worked. Greatly appreciate the assistance.
07-13-2022 10:34
07-13-2022 10:34
Feel free to throw it in the trash.
07-13-2022 10:35
07-13-2022 10:35
What button? The button that BRICKS IT?
07-13-2022 11:24
07-13-2022 11:24
