03-20-2017
06:20
18:17
03-20-2017
06:20
18:17
Hello! So I've had my Alta for about 6 months now. I went to charge it last night and when I put it on this morning it had a full battery and was working fine. After about an hour I went to check my steps and the screen was completely blank and when I tap on the screen it won't show the different screens. I'm not sure if there's just an issue with the battery or if it's completely dead.
03-20-2017 06:48
03-20-2017 06:48
That doesn't sound good. First thing to try is a restart of your Alta:
https://help.fitbit.com/articles/en_US/Help_article/1186/
If the battery has somehow shorted and discharged then you may need to leave it on charge for a little while before trying the restart
03-20-2017 09:25
03-20-2017 09:25
Mine is doing the same thing. Earlier this morning I was a week and several hours off on the date/time. I reset it. Then I just tapped on the front and nothing happened. I plugged it back in to the charger and the time is off again and it hasn't been tracking. The only way to see steps is to plus it into the charger. Frustrated!
03-20-2017 10:13
03-20-2017 10:13
I have the same problem. Will try SteveH'so advice when I get home, but disappointed.
03-20-2017 12:08
03-20-2017 12:08
I have the same problem. I was charging it. It showed that it was fully charged, unplugged it and when I tap on it nothing shows up. I've also reset it based on instructions and nothing happened.
03-20-2017 12:11
03-20-2017 12:11
its also hot to touch..
08-30-2017 03:19
08-30-2017 03:19
Did you manage to get yours working. I have tried the restart and it is fully charged but will not turn on when off charge.
08-30-2017 11:14
08-30-2017 11:14
08-30-2017 12:49
08-30-2017 12:49
08-12-2018 21:01
08-12-2018 21:01
Go to your fitbit app, go under devices, click on your your device, scroll down to the bottom and turn your keep alive and always connected. That worked for me
10-25-2018 05:40
10-25-2018 05:40
I can’t locate that
01-05-2019 15:24
01-05-2019 15:24
I have tried restarting it and still won’t turn on. On my Fitbit app it says it is fully charged but it’s not turning on. I haven’t used it for about a year becuase we have we moving places. Any suggestions now??
02-05-2019 14:16
02-05-2019 14:16
Fully charged Alta won’t turn on unless plugged into power source
03-25-2019 02:58
03-25-2019 02:58
my fit bit is fully charged but the screen is always blank
04-01-2019 13:06
04-01-2019 13:06
Same problem here. Did you find solution?
04-01-2019 14:29
04-01-2019 14:29
04-03-2019 07:06
04-03-2019 07:06
This is a common issue with the Alta apparently. I had mine for two years; it did the same thing (screen blank, gets very hot on charger, phone app cannot find Alta) and I contacted support last month. I had to send them my original Alta and wait for them to receive it and send a replacement. I was grateful they replaced it even though I was without a working fitness tracker for two weeks, however I have had the replacement for about two weeks and it has the exact same problem this morning. I contacted chat support again and they basically said I needed to send it back so they can "investigate" before replacing it again. If you search these forums, this is a common issue with the alta. I had considered upgrading to the versa but now I am considering an apple watch.
04-03-2019 12:38
04-03-2019 12:38
04-05-2019 03:12
04-05-2019 03:12
04-09-2019 18:24
04-09-2019 18:24
Hi @RemyF @Sammyfee @pyramids1234 @Sonniblair @JamaicaNae @SunsetRunner @NellM welcome to the Community! I apologize for the delayed response
@RemyF Thanks for trying to restart your tracker. I contactes Support and was told that you are already in contact with them.
@Sammyfee @Sonniblair Thanks for the information. Have you tried to restart your Alta?
@JamaicaNae @SunsetRunner @NellM @pyramids1234 Thank you for your feedback. I'm glad that Support could help you and/or your device is working again.
Please keep me posted
