07-24-2019
00:12
20:08
07-24-2019
00:12
20:08
Hello,
My alta HR has the green light on and very bright. I've tried to reset the device even delete from the app and re-add with no luck. Any suggestions?
07-25-2019 21:59
07-25-2019 21:59
Welcome to the Fitbit Community @BreMarie01.
I appreciate your participation in the Forums and sharing that the green light on your Alta HR is very bright and won't turn off. Thank you for your efforts to resolve the issue, you can confirm the steps to do a restart from this help article: How do I restart my Fitbit device? I also recommend turning off the heart rate setting by doing the following:
Let me know how it goes, I'll be around!
Best Answer07-26-2019 00:04
07-26-2019 00:04
I have the same problem. I noticed yesterday that the battery had died and I know it was full the day before. I usually get 5-6 days out of it even after 18 months of ownership.
The green lights are so bright I could land aircraft! 🙂
I’ve turned off the HR sensor setting but the lights haven’t turned off. The battery drains in about an hour now because the lights are so bright.
07-26-2019 12:26
07-26-2019 12:26
Welcome to the Fitbit Community @Stoph101.
Thank you for joining the conversation and sharing that you're experiencing the same issue with your tracker. I appreciate your efforts to resolve the issue and would like to confirm if you've tried to restart your device: How do I restart my Fitbit device?
Please keep me posted!
Best Answer07-26-2019 12:31
07-26-2019 12:31
Thanks @LiliyaFitbit, yes restarted following the steps. Also battery drained and restarted again, still incredibly bright green lights.
07-26-2019 14:59
07-26-2019 14:59
Hi @Stoph101, thank you for your reply.
Thank you for confirming the steps to restart the tracker. Since the issue persists, I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Best Answer03-26-2020 05:09
03-26-2020 05:09
Hi there,
I have the same problem as well. Started last week. Battery now doesn’t last a day. Looks like I’ve got plutonium in my bed at night.
Have tried switching off the heart rate in the app but no joy. Have also rebooted at least 20 times, let the battery go completely flat etc.
Any other ideas?
Cheers
06-18-2021 06:04
06-18-2021 06:04
Hi Stoph101
Did you ever get a response to your query? My Fitbit Alta HR is now having the same fault - the green lights are on all the time. I have restarted device, turned off heart rate monitor etc, I wondered if you got yours fixed? I can't get a response from Fitbit at all.
Best Answer07-21-2021 17:06
07-21-2021 17:06
@Sugarpet Any luck getting an answer? Mine is doing this now and all I can get from customer support is that it’s a “feature upgrade” and an “expected behavior” for the device.
Best Answer07-22-2021 00:34
07-22-2021 00:34
Hi NoLMo - having found no solution on this forum I raised a query via their Twitter feed, but it was was a waste of time. Having a case "raised with Tech Support" I got some stock answers about resetting the device or turning off the heartrate monitor. It was obvious nobody had actually read my questions properly. I even let the battery drain completely and left the device for TWO WEEKS and the problem recurred as soon as I plugged it back in to charge up. As the battery was draining so quickly because the lights were on all the time, and so bright, and because the brightness was so distracting to have on your wrist, I no longer use the device. You could try raising a query via Twitter - they might then realise this is not a "feature upgrade" or "expected behaviour" but a flaw. Good luck.
08-03-2021 17:06
08-03-2021 17:06
I’ve been following this feed, trying absolutely everything. The green lights will not go off and my tracker does not stay charged a day. Anything else you can suggest/offer! TIA
08-04-2021 16:12
08-04-2021 16:12
08-04-2021 17:20
08-04-2021 17:20
