10-19-2017
09:32
20:08
10-19-2017
09:32
20:08
My Alta's green light is now permanently on and the battery will not stay charged. It will charge while it is on the charger though. I have restarted/reset the device 4 or 5 times now. And I updated it as well. Please advise.
10-19-2017 11:20
10-19-2017 11:20
Hi @KimberlyNicole,
Try going into the settings for the tracker in the app. Find Heart Rate, turn to OFF. Then sync. Then go back and turn Heart Rate to AUTO, and sync once more.
Let us know if that fixes things for you.
10-19-2017 11:54
10-19-2017 11:54
10-19-2017 18:26
10-19-2017 18:26
I think you probably need to contact support. They will probably be able to sort you out or replace the device.
Helen | Western Australia
10-19-2017 18:27 - edited 10-19-2017 18:30
10-19-2017 18:35
10-19-2017 18:35
@WavyDavey I cant find how to do it on the ionic! But on my Alta HR when I switch to Off and sync the green lights are turned off and when I switch back to auto and sync they come on again.
@KimberlyNicole are your green lights flickering or are they constant?
Best Answer10-19-2017 18:40 - edited 10-19-2017 18:40
Best Answer10-20-2017 04:52
10-20-2017 04:52
10-20-2017 04:58
10-20-2017 04:58
Yes I think support is your best option.
Best Answer03-27-2018 21:08
03-27-2018 21:08
Thanks...worked for me.
Best Answer07-13-2020 10:47
07-13-2020 10:47
FWIW, I contacted support and they were unable to fix my problem. An offer of a 25% discount on a new one followed, but who wants to invest that much money in a watch that lasts three years?
08-24-2020 18:23
08-24-2020 18:23
I'm having the same problem for 3 days now.
