11-15-2018
09:58
20:08
11-15-2018
09:58
20:08
The help page tells me to restart my alta to get the date and time correct...it doesn't tell me HOW to do that! Poor!
11-15-2018 10:05
11-15-2018 10:05
Hi, to restart your Alta there is a small button on the charging cable, whilst connected to the alta press the button 3 times holding for a few seconds each time and then a small pause between each press. If successful you will see the fitbit logo on the screen,. It took me a few tries to get it right
11-15-2018 10:05
11-15-2018 10:05
11-15-2018 10:16
11-15-2018 10:16
Thanks! That got it off and on. But I still have the wrong date and time on it...now how do I make that happen?
11-15-2018 10:22
11-15-2018 10:22
You have to synch the Alta with the fitbit app, which device are you connecting via bluetooth
11-15-2018 10:25
11-15-2018 10:25
My mistake....I can't seem to shut it off...I'll keep trying.
11-15-2018 10:30
11-15-2018 10:30
I just don't get this. I've got an account w/fitbit that I log into and when I ask it to sync it just goes to the help screen that doesn't help me!!!! Very frustrated. I'm trying to do this on Windows 10 computer.
12-29-2019 22:02
12-29-2019 22:02
Cheers for this.... completely forgot about the little button... and how to press it!?!
work on the second go... cheers
