11-21-2020
07:18
06:24
AlejandraFitbit
11-21-2020
07:18
06:24
AlejandraFitbit
How can I adjust the brightness of my Alta display? It is very faint. Thank you.
12-25-2020
06:27
05:22
12-25-2020
06:27
05:22
It's great to see you here, @Annie888.
The screen on Fitbit Ace, Fitbit Alta, and Fitbit Alta HR is dimmed when not in use. It wakes up automatically when you turn your wrist towards you (known as Quick View), or you can double-tap your tracker where the display meets the band as shown below.
To advance between screens and see your stats, give your device a tap. Note that Ace, Alta, and Alta HR don't respond to swipes. If your display is too dim, you can restart the device by following the steps in the article: How do I restart my Fitbit device?.
Let me know the outcome.
Best Answer12-26-2020 02:42
12-26-2020 02:42
Thank you. I know it is dimmed when not in use, but I want it brighter when it is in use.
02-07-2021 16:42
02-07-2021 16:42
Did you ever get an answer to this? I am having the same trouble with mine, I can’t even see it in the daylight
02-07-2021 18:44
02-07-2021 18:44
Hi. I restarted the device (Fitbit Alta HR) by following the steps in the article: How do I restart my Fitbit device?. The outcome: It is still dimmed; very difficult to see what is displayed on the screen.
Best Answer02-08-2021 02:33
02-08-2021 02:33
No reply! I think some FitBits are faulty and just have a dim display. 🙁
Best Answer10-21-2022 08:01
10-21-2022 08:01
I'm having the same problem. And let down by Fitbit's lack of support.
11-05-2022 07:43
11-05-2022 07:43
Me, too. Cannot see it outdoors.
