10-13-2021
17:08
07:35
BraulioFitbit
10-13-2021
17:08
07:35
BraulioFitbit
How do I get device to record in steps instead of km?
10-14-2021 07:34
10-14-2021 07:34
Welcome to the Fitbit Community, @Katbyte59. Thanks for the input, @JohnnyRow.
@Katbyte59 Your Alta HR is always recording your steps as steps. You're seeing a "k" next to your steps because the display orientation is changed so it doesn't show all the steps. For example, instead of showing 1,528 steps, you'll see "1.5k". You can change this from the Fitbit app by tapping on your profile's icon > Alta HR > Clock Display and from there you can switch to Horizontal or Vertical.
See you around!
10-13-2021 19:42
10-13-2021 19:42
It should be automatically recording both steps and distance. Where are you not seeing steps - on device or on phone app?
Best Answer10-14-2021 07:34
10-14-2021 07:34
See you around!
10-14-2021 11:20
10-14-2021 11:20
Best Answer10-14-2021 13:34
10-14-2021 13:34
Hi, @Katbyte59.
It's been a pleasure to assist you 🙂.
On your spare time you can take a look to our Sleep Well board where you can find and share tips to improve your sleep.
Have a nice day!
