01-08-2017
06:22
18:17
01-08-2017
06:22
18:17
I have read the instructions to restart my Alta however I don't have a button on the USB cable. Please could someone help? I don't know how else to reset it. Thanks
Moderator edit: Updated title for clarity
09-29-2019 14:10
09-29-2019 14:10
Unclasp the charger and re-clasp it 3 times in a row. If this doesnt work, try unplugging @ the USB 3 times in a row with 1/2 to 1 second intervals.
Fitbit told me i needed a new official charger ($11 on amazon).... No thanks!
11-03-2019 17:04
11-03-2019 17:04
I have been trying for 5 days to sync my fitbit. The original charger cord broke so I purchased one without the RESET button. Was going to order a new one but your trick worked. Thank you!
11-13-2019 06:50
11-13-2019 06:50
How’s to restart my Fitbit without button
11-13-2019 07:30
11-13-2019 07:30
11-16-2019 20:51
11-16-2019 20:51
12-18-2019 10:03
12-18-2019 10:03
The Plug/unplug method is not working for me. Maybe I just need to buy a new charger.
12-18-2019 16:21
12-18-2019 16:21
12-22-2019 17:44
12-22-2019 17:44
That worked for me. Thanks so much!
01-18-2020 07:35
01-18-2020 07:35
I FIGURED OUT HOW TO RESTART THE DEVICE WITHOUT THE RESET BUTTON! 😃
For those of us without a reset button on the charger:
The first couple of unplugs you'll just see the battery icon go from charging/not charging. When it reboots you will see the Fitbit icon with the little dots and then the software version number flash.
HOORAY!
However, I still couldn't sync my fitbit to my android phone without disconnecting from wifi on my phone and reconnecting again. Bummer.
01-18-2020 07:38
01-18-2020 07:38
@BoxerBoi - Sorry! I didn't see your post until I posted this one! I wish I had found it sooner.
Thanks!!
02-06-2020 15:07
02-06-2020 15:07
e the same issue when I was in New Zealand my cord dont have a button or logo what should I do?
02-06-2020 15:32
02-06-2020 15:32
02-17-2020 13:47
02-17-2020 13:47
Thankyou so much, this has worked for me 👍🏻
04-19-2020 16:31
04-19-2020 16:31
This worked for me--I just kept sliding the USB connector out of the computer 4-5 times and like magic it rebooted.
05-16-2020 16:54
05-16-2020 16:54
AndyB121 you are a STAR! Thanks
05-16-2020 19:32
05-16-2020 19:32
05-16-2020 19:41
05-16-2020 19:41
Excellent question, Puma53
05-27-2020 15:36
05-27-2020 15:36
Did you press it 3 times?
05-27-2020 16:15
05-27-2020 16:15
05-31-2020 12:57
05-31-2020 12:57
My original charging cable broke; it had the button. I purchased another from Amazon, not realizing that not all chargers had the button. So I purchased a second replacement, this time making sure to look closely at the pictures displayed for the presence of the button.
