04-26-2020
07:32
17:41
04-26-2020
07:32
17:41
Hi, I'm trying to get this working for my daughter and think it's an Alta but not sure. Looks similar to an Alta but maybe not exactly the same.
Can anyone identify this?
https://photos.app.goo.gl/ZMaDwi7SWPKH6Kq78
https://photos.app.goo.gl/LWbCQKNnYzUYJk9B6
Thank you!!!
04-26-2020 10:24
04-26-2020 10:24
If it has any charge, you can try setting it up and see which model it accepts, but I am guessing battery is dead and don't have charger, or know which one to get.
I don't have Alta but bank doesn't look same - Alta has removable band not visible here, and connector looks different.
pic from Alta manual
The inside of your band looks like it has a "W" logo.
And the red fingerprint-like swirl on screen is not familiar.
I'm wondering if it even is a Fitbit, or another brand.
Best Answer04-26-2020 10:24
04-26-2020 10:24
Best Answer04-28-2020 09:03
04-28-2020 09:03
Thank you - I think you're right
