01-10-2018
11:46
20:08
01-10-2018
11:46
20:08
With the Alta HR is it possible to input a previous days food information?
01-10-2018 12:44
01-10-2018 12:44
@Keelyfc -
Well it looks like we will be going to the web site.
Go the main web dashboard:
Again - good luck.
01-10-2018 11:57
01-10-2018 11:57
@Keelyfc -
Yes you can entry food for a previous day. I do it frequently, mainly because I enter a lot of custom food items into my account and sometimes don't have the correct figures until a day later.
I am going to give instructions on doing so using your phone - If you need instructions for using the web, let me know in a reply to this post.
In the app:
Tada!
Good luck and welcome to the boards.
Best Answer01-10-2018 12:01
01-10-2018 12:01
Thanks, only it doesn’t show yesterday in the list! It shows Monday after today! I didn’t enter anything at all yesterday...
01-10-2018 12:44
01-10-2018 12:44
@Keelyfc -
Again - good luck.
01-10-2018 12:49
01-10-2018 12:49
Great thanks, it’s not working on my phone but I’ll try the computer tomorrow 👍
Best Answer01-10-2018 12:53 - edited 01-10-2018 12:56
@Keelyfc -
Sorry - I completely forgot that when you select a food to add in the phone app on the screen where you have "Save" at the top right, you can change the date just below where you select which meal.
You can only go back two months, but you only need one day.
Stooooopid me.
Best Answer01-10-2018 13:03
01-10-2018 13:03
Great! I’ve done it thanks! 😁
Best Answer02-24-2018 16:20
02-24-2018 16:20
This helped me for my Charge 2. Without this information I could only add food on previous days if I had added at least one item...my biggest problem was logging but not saving. Thank you.
Best Answer02-08-2019 00:38
02-08-2019 00:38
The only thing that you can't add to another day is "quick calories", unless you've already added a normal food item in order to have a log for whichever day.
I forgot to log yesterday, but quickly added the calories (I had to manually add since everything was customized) and I had to add it as a custom food that I just labeled "daily intake".
Best Answer01-10-2020 21:31
01-10-2020 21:31
I am using the Fitbit app in Android. There is no dashboard from what I can see. The day has ended, it is after midnight and I can no longer enter food in yesterday's calories in. The entire day is present in my head but can not be logged into my Samsung S3 Tablet.
Best Answer01-19-2020 18:18
01-19-2020 18:18
It doesn't show Friday. So how can I edit it?
Best Answer10-05-2020 07:32 - edited 10-06-2020 06:01
This has happened two days in a row now. I logged my breakfast and yesterday's breakfast appeared as well. However today (Monday), both Sunday and Saturday breakfasts appeared. This is a nuisance. I know how to delete, I know how to use the log. What's happening here...? UPDATE: THREE days in a row....
