07-13-2021 00:21
07-13-2021 00:21
Hi I’ve had my Alta HR for about a year and I can’t read it AT ALL outside. I’ve never been able to but now it seems it’s getting worse…I can’t see it inside either unless it’s almost dark! Really frustrating as I have to carry my phone and synch (which takes a long time, also frustrating) to see progress.
Reset doesn’t work and there’s nothing else I can find to fix it!
Thanks,
Michelle
07-13-2021 08:48
07-13-2021 08:48
One possibility is that you are accidentally in 'Sleep Mode' which intentionally keeps display dim. A quick check for that is if turning your wrist turns on display. If not, you are in Sleep Mode.
07-18-2021 02:42
07-18-2021 02:42
Thanks for your reply but that’s not the issue. I appreciate you taking the time though.
Best Answer07-18-2021 10:48
07-18-2021 10:48
Same issue! I can’t see anything unless it’s dark. It used to be (literally like a couple of weeks ago) that I couldn’t see it in bright day light or sunlight but now it has to be night for me to see anything. Mine is a few years old now so I wondered if it was that but appears to be an issue regardless of age
07-23-2021 21:05
07-23-2021 21:05
HI Helen, Thanks for your input. I've found it really difficult to get back in here to reply! I have also noticed the charge is not lasting like it used to on my Fitbit. Apparently others have had that issue as well.
07-27-2021 15:38
07-27-2021 15:38
How do I get it off sleep mode? Does the display light die?
