11-24-2021
05:20
12:35
11-24-2021
05:20
12:35
I’ve tried everything deleting app, restarting phone, restarting tracker, and still won’t connect. I even restarted it and time is not right.
11-24-2021 12:38 - edited 11-24-2021 12:38
Hi there, @Loriwarriorsull. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Alta HR before reaching out.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Alta HR automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, see Why won't my Fitbit device sync?
Hope that helps.
11-24-2021 17:57
11-24-2021 17:57
Best Answer11-25-2021 05:58
11-25-2021 05:58
I think the internal bluetooth in the alta HR stops working. I too tried all of the hints and tips but nothing helps. When I tried setting it up as a new device, the software would find my fitbit then the fitbit would display the 4 numbers for me to enter. I enter the numbers but then it never connects. I keep getting "Try Again"
I even tried pairing it with my laptop and also my work computer. On my work computer, bluetooth found it and asked if I wanted to pair it with the computer. I confirmed then it popped up and said it was an invalid device.
I agree with you! I thing the device took a dump. It's right on the edge of going into the trash...like you, I'm tired of spending so much time on it - in my case almost 2 full days of research and trying.
Best Answer11-25-2021 06:22
11-25-2021 06:22
11-29-2021 16:50
11-29-2021 16:50
This is an Apple rip off. My wife and I both have an Alta HR.
I use mine daily, my wife upgraded and it has sat idle for almost a year (but charged). At the same time, BOTH lost their screens but could still sync with the app. Last Friday, the app wouldn't sync. The 'Fix Now' button provides no option to 'fix'. I tried the Apple directions on here to unfollow etc and now my iphone can't find it.
All very suspect!
Best Answer11-29-2021 16:53
11-29-2021 16:53
I use mine daily, my wife upgraded hers but the ALTA HR has sat idle for almost a year (but charged). At the same time, BOTH lost their screens but could still sync with the app on my phone. Last Friday, the app wouldn't sync. The 'Fix Now' button provides no option to 'fix'. I tried the Apple directions on here to unfollow bluetooth and reconnect etc and now my iphone can't find it to reconnect.
All very suspect! Any advice would be welcomed!
Best Answer12-08-2021 15:14
12-08-2021 15:14
Best Answer12-18-2021 13:19
12-18-2021 13:19
I had this problem and what seemed to finally work was resetting the Alta HR several times in a row. I did the 3 taps on the button (you will feel a vibration on each tap) on the charging cable within 8 seconds leaving about 5 - 10 seconds in between each attempt at restarting. I repeated this until I saw "ALTA HR" appear on my phone's Bluetooth pairing device screen. Don't give up if it doesn't happen right away; it took several times.
12-18-2021 18:15
12-18-2021 18:15
Best Answer12-18-2021 18:44
12-18-2021 18:44
Best Answer12-19-2021 00:34
12-19-2021 00:34
12-19-2021 00:35
12-19-2021 00:35
Best Answer12-19-2021 10:08
12-19-2021 10:08
