04-18-2018 15:39 - last edited on 08-20-2020 20:08 by MatthewFitbit
So I lost my Alta HR a supper long time ago. My mom got the newest fit-bit set it up and gave me her old Alta HR. I set it up. when i did it was displaying everything that it needed to. as soon as it was fully set up it stopped displaying anything. i put it on the charger and it would not even show the little battery. I tried resetting it and it vibrated and showed nothing. it is just like my fit-bit is working but the screen is not connected. can someone help.
04-18-2018 19:53
04-18-2018 19:53
Try several restarts in a row. If that doesnt help then you will need to contact Support (link in my signature )
Helen | Western Australia
04-18-2018 19:53
04-18-2018 19:53
05-28-2019 23:19
05-28-2019 23:19
I will try this as my fit bit is doing the same thing
thank you
03-28-2020 22:49
03-28-2020 22:49
I’ve lost mine but if found it but I’ve plugged it in for a while but it won’t turn on. I’ve tried restarting it several times. I really hope you can help.
