04-29-2020
10:08
17:41
04-29-2020
10:08
17:41
It seemed like I was always charging and resetting my Fitbit, so I started keeping a log. I have had to charge it everyday for the last week and reset it twice. Once, the full charge only lasted 2 hours. This is getting ridiculous. What else can I do?
05-06-2020 17:48
05-06-2020 17:48
How old is your Alta @erin304. The battery does have a limited life.
Best Answer05-08-2020 06:28 - edited 05-08-2020 06:30
Less than a year. I got this one in June. But this problem has been happening since November, I just dealt with it.
Best Answer05-08-2020 19:59
05-08-2020 19:59
I am having the same problem. When I sync it with my phone, it says I have 75%battery left.
Best Answer05-11-2020 19:33
05-11-2020 19:33
do you know if the battery can be replaced?
Best Answer05-13-2020 15:08
05-13-2020 15:08
Just wondering if you had an answer to your question as I’m having the same trouble - I am thinking the battery needs replacing as I’m having to charge it every 2 hours and when I do put it back on charge it says it’s fully charged .
not sure how I reset it though
Best Answer05-14-2020 00:25
05-14-2020 00:25
Best Answer05-14-2020 02:02
05-14-2020 02:02
Best Answer05-14-2020 12:34
05-14-2020 12:34
Some of them don’t have one. See if you can buy one on eBay.
Best Answer05-14-2020 12:37
05-14-2020 12:37
I do that, it doesn’t help. But I also do think I should HAVE to do it every time. That’s just ridiculous
Best Answer05-14-2020 12:46
05-14-2020 12:46
Look at your charger (the USB part). Is there a button? If there is, start charging the Fitbit. Press and hold the button for 3 seconds, 3 times in a row. The Fitbit screen will show the charging diamond and it’s reset.
Best Answer05-15-2020 20:09
05-15-2020 20:09
Best Answer05-17-2020 00:22
05-17-2020 00:22
I've been having a similar problem for about the last 6 weeks. Mine is holding battery life for around 5 days but when I do charge it the battery icon on my Alta Fitbit is solid in colour but when I take it off the charge and tap it nothing happens and the screen is blank. I then have to reset it. When I do this the battery icon displays less than half charged. I'm also finding that it gets to about half charged on the battery icon and then next thing it's dead. I have to reset it after ever charge in order to get t to work agan and then sometimes I have to recharge it again.
