09-30-2021 19:35
09-30-2021 19:35
My Alta keeps shutting down even with 70% battery level. It has been doing this for the past 2 weeks. Out of no where, i can go to check the time or my steps and no matter how many times I tap on it NOTHING!
I have to hook it to the charger just to get it to power back on!!
At first I thought the battery might be low, but then it will show it still has 50% or more battery power left.
C’mon Fitbit, what’s the deal???
i see there has been other posts about this!!
10-18-2021 01:55
10-18-2021 01:55
Hi @Yahne76 Have you tried restarting you Alta several times? If not give this a try. If it continues to randomly shut down then sadly it is dying.
Helen | Western Australia
10-18-2021 10:56
10-18-2021 10:56
I'm having exactly the same issue
10-19-2021 09:07
10-19-2021 09:07
Did your Fitbit get replaced or fixed?
10-20-2021 10:24
10-20-2021 10:24
Yes i have tried restarting it.
The only thing that has worked is me charging it every night.
My cousin who has the first Inspire fitbit has been having the same issue.
i wonder if this is a Fit it software issue….
i just know as a long time Fitbit customer, these constant software issues are making me frustrated and ready to jump to another brand!!
10-20-2021 10:29 - edited 10-20-2021 10:30
No because it is out of warranty so l am S.O.L.
They need to start offering some third party warranty like square trade
And I’m not going to buy another Fitbit if this is a software issue!
My cousin has the 1st Inspire tracker and she has been having the same issue!!
I AM COMPLETELY FRUSTRATED WITH FITBIT🤬
10-20-2021 10:41
10-20-2021 10:41
