07-24-2020 12:20 - last edited on 08-20-2020 17:41 by MatthewFitbit
Last three days Alta not charging beyond 80%, even overnight. When I put it on it shuts down right away. I’ve had ‘tis Fitbit for about a year & have had ongoing problems of this type. Not sure if I’ll want to buy another one eventually as am not too happy with this product. Please help!
07-28-2020 00:17
07-28-2020 00:17
I am sorry you are facing this. My Alta battery is discharging way sooner too since a couple of months, but mine is over three years old now, so I cannot really comment on your relatively new band issue.
But seeing multiple similar battery discharging too soon/not charging/going blank issues on the Alta forum - perhaps a FitBit moderator help address this recurring coincidence in the Alta community?
07-28-2020 08:01
07-28-2020 08:01
That would be a great idea. My Alta is two years old and does the same thing. With a full charge, I can be in the midst of a 4 mile walk, and look down to check steps and time and the darn thing is dead. No response. I am having to charge it almost every day, and the sync pattern is messed up, as well.
07-28-2020 08:57
07-28-2020 08:57
07-28-2020 10:21
07-28-2020 10:21
I am also having the same problem with my Alta. 🙁
07-29-2020 03:48
07-29-2020 03:48
It happens the same to me (my Alta is also about 3 years old). Any moderator who could help us?
Thanks!
07-29-2020 10:46
07-29-2020 10:46
Having a somewhat similar problem. Today during my walk it just stopped recording everything about half-way through the 45 minutes. When I got home I tapped on it and it was dead. I plugged it into the charger and it showed the battery level to be basically empty but within about five minutes of it being plugged into the charger, it was up to 80%. My Alta is now five years old. I think these things have a planned obsolescence of about two years. I'm thinking about getting a Flex but I read those boards and people have lots of problems too.
07-29-2020 23:39
07-29-2020 23:39
I face the same as you guys and feel really unhappy with fitbit for not doing anything about it. I contacted them and they proposed absolutely nothingif your watch alta is older than ayear so not under warranty anymore. For me, bad luck euh) it started within the second year of usage and I haven’t used it much before that. The pattern here is that it stops while still on an 75-80% battery charged, never goes below that as it simply shuts down As if discharged. I charge it Overnight to 100% and it discharge to 80% within half day or so... in short: useless. This is clearly abug that fitbit should address as it affects numerous users. Nobody buys a watch at that price so that it lasts only one year! So very much hoping someone competent and conscientious from Fitbit can reply and help.
07-30-2020 16:38
07-30-2020 16:38
Mine is doing the same thing I have tried to reset it anyone else get any way to fix it?
07-31-2020 03:49
07-31-2020 03:49
Just adding to the list... same experience. My Alta is about 2 years old; stops working when battery depleted to 80% (only turns back on once plugged in again even though battery always says unit is still 80% charged).
Is there any Fix for the bug? Is there any effort to make this right? Is there even a coupon for a replacement?
07-31-2020 06:32
07-31-2020 06:32
Mine is doing exactly the same as all the others. Shuts down, unable to sync, only two years old. Going back in the box and will not replace with Fitbit.
07-31-2020 14:13
07-31-2020 14:13
Same here. It starts back up on connecting to the charger. Otherwise it dies within a few hours. Mine is 4 years old
08-03-2020 14:54
08-03-2020 14:54
Having the same issue too, battery is fully charged, works for around half an hour the. Turn off and have to connect to charger which is showing as battery power is 88 percent or so. Not sure why this is happening really quite annoying.
08-03-2020 16:31
08-03-2020 16:31
Obviously this is an operational programming issue, since it is happening in New AND older models of the Alta Fitbit. It is frustrating and discouraging. I will NOT buy a replacement from Fitbit.
08-03-2020 16:51
08-03-2020 16:51
08-03-2020 18:05 - edited 08-03-2020 18:07
Tried it. Seems working for a very short time, then started allover again. But many thanks to you for sharing it! Frankly, the fact it’s happening to so many of us is no coincidence and the fact we aren’t getting any reply or support is tremendously and growing’y frustrating. Starting to think about what we could do about it, because a watch at that price that doesn’t operate well after a year from a brand that feels no need to fix it is just a scam.
08-04-2020 03:35
08-04-2020 03:35
Same here - totally fed up - obviously a software problem so an update should sort it. Mine's was new at Christmas, but replacement 3 or 4 - what a load of rubbish they are!
08-04-2020 03:54
08-04-2020 03:54
Update!!! I have got a replacement on the way!
The wait from 32 in chatroom queue dropped pretty quickly. I had typed this out ready to paste in and after checking a few details, I had success.
"Every few days my Alta shuts down during my exercise, even though when I sync the battery shows as well over half charge. A lot of people in the forums have been reporting the same in the last two weeks - you clearly have a software problem. I received this one on Christmas Eve so it is less than 8 months old. What a poor product - so not worth the money!!!"
I also pressed that so many had reported the same thing here, in less than two weeks, and asked him to report upwards for technical investigation into the software. He agreed!
08-09-2020 08:03
08-09-2020 08:03
I have reset my Alta, several times, with the same result...nothing changed. When I reset, the time is off. I go to resync to fix it, and the program cannot find the device. I am just about ready to throw in the towel. Who said we had to know how many steps we were walking a day, anyhow? Does it matter? We are going to walk, anyway. I know how far my walking route is and how often I walk it. Pulling my Seiko out of the jewelry box and replacing the battery. Throwing the Alta in the trash where it belongs.....
08-09-2020 12:11
08-09-2020 12:11
Thanks and congrats to you! Was your Alta still on warranty ?
