04-15-2019
03:51
18:17
04-15-2019
03:51
18:17
I tried restarting but nothing happens?
do you have any ideas?
if so contact me pls
04-16-2019 13:59
04-16-2019 13:59
Thank you for the provided information @fitty-bitty567. I'll be glad to continue assisting you.
I went ahead and created a case on your behalf and a customer support representative will contact you soon.
Please let me know if you need further assistance.
04-16-2019 08:40
04-16-2019 08:40
Welcome to the Fitbit Community @fitty-bitty567! I´ll be glad to assist you with your Fitbit Alta inquiry. Thank you for letting us know that you have already tried restarting the device.
Does your Fitbit turn on when it´s not charging? Is the battery charged? What are you able to see when your device is charging?
I´ll be waiting for your responses.
Best Answer04-16-2019 13:23
04-16-2019 13:23
04-16-2019 13:59
04-16-2019 13:59
04-16-2019
15:51
11:50
AndreaFitbit
04-16-2019
15:51
11:50
AndreaFitbit
I just got my Fitbit Alta 4 months ago and this happens. Very disappointed. I tried restarting my Fitbit Alta multiple times by clicking the button 3 times within 8 seconds but it still does not work. Please can someone tell me how to fix this issue.
Moderator edit: removed personal information.
04-17-2019 12:01
04-17-2019 12:01
Welcome to the Fitbit Community @Sohaib_H. I'll be glad to assist you with your Fitbit Alta inquiry. Thank you for letting us know that you tried restarting your device.
I went ahead and created a case on your behalf and a customer support representative will contact you soon. You can mention your brother's device too.
06-16-2019 07:05
06-16-2019 07:05
I have the same issue. Battery is fully charged, phone app confirms this, but the fitbit won't work once unplugged. Works fine while plugged in. Resetting the fitbit does nothing.
06-16-2019 08:35
06-16-2019 08:35
Facing the same issue. Alta displays all data only when plugged in to charger. Tried cleaning part and restart step too. No progress. Same issue again.
03-03-2020 15:55
03-03-2020 15:55
Mine does the same thing. Help
03-13-2020 08:57
03-13-2020 08:57
I have also been having the same problem for several months. I bought a new charger cord as previously instructed. I've rebooted many many times. And yet, it only works when plugged in. The app says it's charged. Help!!
06-18-2021 11:00
06-18-2021 11:00
Did anyone solve this issue? I am having the same problem...
06-28-2021 22:16
06-28-2021 22:16
Same here!
First I restarted my Alta, but it still shuts off as soon as I unplug it from the charger.
Then I tried deleting the app and reinstalling it. Problem remains.
So I bought a new charger, in case the old one were the problem. Nothing new, still the problem remains.
What do I do?? This was not issue with my Gen1 Fitbit…
06-30-2021 07:31
06-30-2021 07:31
NOPE, I've had the same problem for several months now. Still looking for the correct fix☹
07-12-2021 03:02
07-12-2021 03:02
Same thing happening to my son's Alta. Plug it in, display shows and it syncs to the app. As soon as he puts it on the screen switches it off.
07-12-2021 20:57
07-12-2021 20:57
Same!!! Did you ever find a solution?
07-28-2021 09:09
07-28-2021 09:09
Nope! And it doesn't appear as though the company has either. Personally, I don't even think the company cares and hopes we will just give up and buy a newer version of their problems. I refuse to go that route.
Best Answer07-31-2021 16:38
07-31-2021 16:38
I'm having the same problem with a brand new ALTA. HELP!
Best Answer08-01-2021 06:00
08-01-2021 06:00
Same problem exactly.
Best Answer08-01-2021 08:24
08-01-2021 08:24
08-01-2021 12:01
08-01-2021 12:01
Ended up buying a new Charge 4. I took the Alta to UBreakIFix and they said it is the battery. Possibly could have overheated in FL sun. Walmart carried the battery and tool kit but I couldn't do it and UBIF wanted more than buying a new unit. I gave up. Several people having this issue I tend to think Fitbit knows of the issue and that we end up buying a new unit. They know what they're doing. Especially when no one offers to help. Charge 4 is okay. Again, not nearly as bright as I need it to be outdoors when running in sunlight. Might jump to an Apple Watch next time.
