07-14-2016
06:59
18:17
07-14-2016
06:59
18:17
07-22-2020 09:55
07-22-2020 09:55
You mention in Step 2 that the Fitbit would be charging when plugged in...this is exactly where I am having a problem. It will not charge! I have cleaned the pins and receptors with a q-tip multiple times. I tried to reset the Fitbit, but that won't work either. Any ideas?
07-22-2020 12:45
07-22-2020 12:45
I have done the reset procedure. When I take it off the charger the fitbit does not work
07-22-2020 15:18
07-22-2020 15:18
07-25-2020 11:54
07-25-2020 11:54
I DO NOT have a button on my charging cable. It was purchased in April 2019, has the cable changed since then?
07-25-2020 12:12
07-25-2020 12:12
07-29-2020 11:29
07-29-2020 11:29
I almost did not notice the button. On mine, it is a round circle about a 1/4" in diameter.
07-29-2020 12:04
07-29-2020 12:04
07-30-2020 19:20
07-30-2020 19:20
So after reading thru a bunch of things I followed a variety of steps and got my Alta working.
1 cleaned back charging area with Lysol wipe and charger also
2 used original charger connected to
computer and pushed the button 3 times quickly
3. Charged Alta to 100 percent
4 disconnected Alta from Bluetooth and reconnect
now showing 100 percent charged and reconnected
thanks for all of the suggestions
07-30-2020 20:00
07-30-2020 20:00
The button is a small barley noticeable on the USB end. If plugging into laptop, it should be on top right where the fitting starts to thin down.
08-05-2020 07:37
08-05-2020 07:37
I had to re-install my fitbit on my computer. That FINALLY worked!
10-15-2020 16:14
10-15-2020 16:14
Thanks, I was having the same problem, so I did it as fast I could and worked. 👍😊
Marie T
10-15-2020 16:18 - edited 10-15-2020 16:19
Thanks Joy, I tried super fast and it worked. 😊👍
10-16-2020 14:09
10-16-2020 14:09
I have tried this about 10 times and it’s not working for me.
11-14-2020 14:26
11-14-2020 14:26
I tried the 3-4x unplug usb end from computer 3 times then a quick 3x reset button and wah lah it came back to life.!! Thanks 🙂
11-15-2020 06:11
11-15-2020 06:11
11-15-2020 09:33
11-15-2020 09:33
02-16-2021 22:59
02-16-2021 22:59
Thanks Joy, this well & truly worked for me!
07-24-2022 08:43
07-24-2022 08:43
This worked for me too. I had the EXACT same issue and then I pressed it 3 times quickly without waiting in between and the log came on. THANK YOU for posting
