08-03-2021
10:49
18:16
08-03-2021
10:49
18:16
My Alta HR is not syncing last sync was at 8:16 last night can I get some response soon thank you
08-03-2021 11:25
08-03-2021 19:21
08-03-2021 19:21
My Alta hr won't sync to my Android phone last sync was at 8:16 last night I'd appreciate a response please
08-03-2021 20:24
08-03-2021 20:24
@Tedda your post was moved into this thread where you already got an answer earlier. Did you check out the suggested article?
08-11-2021 21:06
08-11-2021 21:06
I was having the same issue with my Alta HR not syncing to my iPhone for about 2 weeks. There had been two previous app updates that did not fix the issue, but I just found out there was a third update not too long ago. So, I updated the app, forgot the device in my phone's BlueTooth settings, and reset my watch (by pressing the button on the charger x3 while the watch was attached). Then, I went in the app and re-paired my watch. I'm not sure which one of those steps worked, but my watch is syncing now. Maybe one of these steps will work for you?
