12-28-2019
10:51
20:01
12-28-2019
10:51
20:01
I bought a new Alta HR last month and whilst on the whole I'm very happy with it, I've noticed in the last few days it has stopped logging daytime naps.
Due to my shift pattern, daytime naps are a common occurrence and count towards my daily total so if it's not logging them it looks like I've not had enough sleep.
I could understand this issue if the device was a few years old but I've had it only a month (from new) and it's quite a frustrating flaw.
12-28-2019 12:04
12-28-2019 12:04
It should automatically record naps of at least one hour.
Less that that it probably won't.
If that is the issue, you could try using the 'Begin Sleep Now' from the plus sign at top right within sleep tile, and then tap again when awake. That's not generally recommended as it can prevent detecting sleep stages, but I sometimes find it useful for shorter naps, though I have never seen it officially suggested.
12-28-2019 12:12
12-28-2019 12:12
Thanks for your reply. My naps are usually a minimum of 2 hrs so I would imagine they should definitely record them as that's a fair chunk of sleep.
