05-06-2020
07:18
19:19
05-06-2020
07:18
19:19
A couple of weeks ago my fitbit went dead -- no display, wouldn't sync, wouldn't charge, even though the battery was not dead. I did the reset by repeatedly pushing the button on the charging cord, and it came back to life -- for a couple of days. Since then, every 1-2 days it goes dead again and I have to do the reset. It happens randomly, so I'm getting gaps in my data between when it goes dead and when I realize it's dead and restart it. Is it dying, or is this a firmware issue?
05-06-2020 18:06
05-06-2020 18:06
How old is your device, and for how many months was the battery left dead to self destruct?
05-06-2020 18:22
05-06-2020 18:22
05-07-2020 02:25
05-07-2020 02:25
I've just got the same problem, had it 2 years, has kept crashing every few days for the last 3 weeks. Always wear it and charge it regularly.
05-11-2020 05:44
05-11-2020 05:44
hello rich I am having the same problem This started 4 weeks ago and switched off within 10 min or so from re starting using the button on the usb charger so can’t get it to stay on for more than a few minutes
05-11-2020 08:16
05-11-2020 08:16
I'm having a similar issue too. Got the Alta HR in 2017. I left it unused for 8 1/2 months, charged it again this April and had a little trouble getting to sync initially. After a day or two it fully synced and it was perfect for about 4 weeks.
Two days ago it crapped out - no display. No response when I put it to the charge cable. It did start up when I hit the reset but syncing again took a long while. The heart rate readings seemed low so I gently cleaned the back of the sensor with a swab and a little isopropyl alcohol.
Now I've discovered it has crapped out again and didn't record any sleep last night. Restart has seemingly worked for now but this may be the beginning of a cycle of power downs.
Any help is appreciated!
