05-02-2019
00:39
18:17
05-02-2019
00:39
18:17
I recently got a Samsung A50 phone. I have tried to connect my fitbit alta to the phone but it isn't working. Does Fitbit support the use of a Samsung A50 and if not when will it be supported?
01-23-2020 07:42
01-23-2020 07:42
I was very happy with the way charge 3 worked with my last phone, but it will not sync messages to my a50. I see thru this thread that most everyone is having the same issue. How did you get yours to work??
01-23-2020 07:54
01-23-2020 07:54
My kid set it up for me. Will check and get back to you.
01-23-2020 09:00
01-23-2020 09:00
I get Fitbit notifications and reminders but not phone call notifications. You can swipe sideways and check to see if Notifications is set to On.
01-23-2020 09:05
01-23-2020 09:05
Going back to our troubleshooting, here are the things you need to do if your Fitbit Charge 3 can no longer receive notifications from your phone…
01-23-2020 09:26
01-23-2020 09:26
1) Go to the App
2) Account
3) Set up device
4) Choose... Charge3 (or your device name)
4) Notifications
5) Set Calls to ... On; set Text messages to On; Calendar Events to On
hope this helps
01-25-2020 09:09
01-25-2020 09:09
It is very unfair. It is not informed in the box or by the seller that it is not compatible to all android. I have a samsung now and thought have upgrade it with fitbit but looks like it is worse. Non of the review spoke about compatibilty
01-25-2020 09:38
01-25-2020 09:38
01-25-2020 10:43
01-25-2020 10:43
I have now fully synced my Samsung A50 to my Fitbit. It works fine. I get a notifications when a text message is received and I can actually read the message on my fitbit once. Just follow the steps I posted. It should work. It works with Carge2 and Charge3.
01-25-2020 10:44
01-25-2020 10:44
And that's because it IS compatible.
01-25-2020 10:46
01-25-2020 10:46
Oh I see now what is happening 😞 Thanks for alerting me NeilRay!
02-22-2020 19:06
02-22-2020 19:06
The first message on this thread was May of 2019, now almost a year later they are still handing out the same non-answer as to either what is a reasonable work around or when are they going to find a way to work with this phone. If its unfixable then post that somewhere prominent so that we don't have to waste our time.
02-26-2020 02:55
02-26-2020 02:55
I found this thread when chat support told me that my A50 is not compatible with my Versa 2. Like, what? The list of compatible Samsung devices is incredibly short, I was actually shocked.
Now, I actually do get my notifications come through after going through various notification settings. Checking the WhatsApp app on the list of notifications on the Fitbit app did not work, so tried unchecking it, then syncing, then checking the app, and syncing. And boom, notifications come through.
However, what doesn't' work is GPS tracking. It's 25% off in measuring the distance, although the map shows the correct route. This has a knock on effect on cardio fitness score etc, running distance comparison etc. Chat told me it's because the A50 is not compatible, so the GPS signal drops every now and then, leading to the map showing a consistent route, but the measurement of the length of that route is off. Seems like an easy fix would be to get the distance measured based on the mapped route, and not consistency of GPS signal. But then again, I'm not a software engineer, maybe this is impossible to do 🙄😂
This issue came up in the autumn 2019, about 5 months after I bought my A50, and has been consistent ever since. I thought maybe it was the old Fitbit Blaze causing the issue, but now my brand new Versa 2 has the same problem.
Very frustrated, and totally regret I didn't go for the Samsung watch like those above in this thread. Get your act together Fitbit or you'll lose your customers!
04-27-2020 13:03
04-27-2020 13:03
When will the galaxy A50 be supported? I see you were working on it in July.. yet I still have issues today, late april..
05-05-2020 05:36
05-05-2020 05:36
I have an a50 and I just got a new fitbit as a gift, it's been a year since this post and it still isnt compatible
05-05-2020 08:28
05-05-2020 08:28
Actually, Fitbit DOES NOT not work on that phone AT ALL.
It’s a Samsung Android.. higher than version 7 .. what makes it incompatible?
05-05-2020 08:31
05-05-2020 08:31
Why would you have to test all the phones that come out??
Samsung A50.. an Android OS version 9... Garmin works on it, why not Fitbit?
05-22-2020 11:14
05-22-2020 11:14
I updated mine, but it still isn't working. It is ridiculous that it's taking so long when so many people have had this issue.
05-22-2020 11:20
05-22-2020 11:20
It is not compatible as the FitBit respondent has stated. That doesn't mean it will NEVER work, but there could be issues. You are just lucky that it worked for you. It doesn't work for everyone because it is NOT a supported device.
05-22-2020 11:25
05-22-2020 11:25
OVER. Year later and it still isn't fixed. This is ridiculous. I guess when this Fitbit goes out, because at this point, I'll just go with a Samsung watch that will actually work. It's ridiculous that I spent so much money on a watch that doesn't function with a phone even though all the other Samsung Galaxys I've had in the past that works fine.
05-22-2020 12:16
05-22-2020 12:16
I finally got my FitBit to connect, after trying everything else, by doing a factory reset if the FitBit. (I have the Versa.)
